That would be a bad case of antifreeze in the oil. I've seen this a number of times with blown head gaskets or cracked blocks. If a lot of antifreeze gets into the oil and is cooked with engine heat it turns the oil into this Jello like substance.
If you can get it repaired quickly and before your journal bearings go out you can get the jello out with Varsol. Not saying they should, but they can.
