Results 1 to 10 of 10
Thread: Giant micrometer - GIF
    baja (12-06-2020), jimfols (12-05-2020), nova_robotics (12-05-2020), Tonyg (12-06-2020)
    Sep 2015
    Ontario Calif USA
    Recon what the resolution is, 0.500 inch?
    Jim
    Supporting Member McDesign's Avatar
    Sep 2016
    McDesign's Tools
    Yeah - that can't really be called a "micro"meter - maybe just "meter".
    It's like the optical engineer I used to work beside, with a wooden yardstick he claimed was calibrated "in wavelengths of light".
    Forrest
  5. The Following User Says Thank You to McDesign For This Useful Post:
    Sep 2015
    Ontario Calif USA
    I would have had to ask the engineer 'what color'.
    Jim
    Sep 2016
    McDesign's Tools
    Ah - we worked with lighting LEDs, so 450 nM - "royal blue".
    All illumination LEDs actually make light at this wavelength, and are coated with phosphor to absorb some portion of this wavelength, and reradiate it at a variety of longer wavelengths, or colors. Our eye mixes all this together as various degrees of "white". There are a couple of boutique LED makers that use a 405 nM "pump" to get some more energy in the near UV area.
    He was a smarter guy (a couple Masters degrees as well), but I think I have more patents.
    That's better, right?
    Forrest
  8. The Following User Says Thank You to McDesign For This Useful Post:
    Oct 2016
    old kodger's Tools
    Depending upon how "stiff" the arc framework is the resolution might be a lot less than .5". I wouldn't be surprised to find it down to nearer 10 or 20 thou.
    The problem is at what time of day he seems to be measuring steel, and the gi-crometer looks like aluminium coefficients of expansion would play havoc with that
    I suppose it could be made of titanium.
  10. #7
    Mar 2014
    Beaumont, TX
    Paul Alciatore's Tools
    Mechanical clocks (and electronic ones for that matter) can be compensated for temperature changes. Why couldn't the frame of a micrometer also be?
    Paul A.
  11. #8
    Jul 2016
    It may have to.be calibrated often, perhaps multiple times a day. The extra long "dumb" anvil might play a part here as a way to efficiently calibrate. Just a guess
  12. #9
    Oct 2016
    old kodger's Tools
    maybe even recalibrated before every use
  13. #10
    Large measuring instruments. Westinghouse Electric Corporation. 1910.
    Fullsize image: https://s3-us-west-1.amazonaws.com/h...s_fullsize.jpg
  14. The Following User Says Thank You to Jon For This Useful Post:
    jimfols (12-08-2020)
