Results 1 to 10 of 11
Thread: Grinder improvements (wire wheel bushing/hub)
  1. #8
    Sep 2018
    I solved a vibration on a small sanding disc for glue on sandpaper. Used a propeller balancing jig and the found the light side and drilled a hole for smal screws. Then just screwed in small screws until i got it basically vibration free. You could just drill a bunch of evenly spaced holes and then add or subtract to get it balanced.
  2. The Following 2 Users Say Thank You to mbshop For This Useful Post:
    craig9 (Mar 9, 2020), Jon (Mar 4, 2020)
