Thread: HAND GRINDER MOUNT BRACKETS
    Apr 2018
    southern Calif.
    paulk's Tools
    Angle grinder tool post mount brackets.
    Enables you to mount an angle grinder to a lathe, drill press, or mill for accurate metal work.
    There are many types of disks available, enabling you to Grind,Cut,Sand & Polish.
    This setup uses the grinder handle holes to locate the bracketry. The
    brackets consist of two pieces of flat stock, one piece of square tubing
    welded to one half inch square rod or keystock.
    1. Grinding a center point for a lathe on a Shopsmithdrill press using an XY table.
    2. Grinding round stock on a Shopsmith wood lathe that has been
    converted to a metal working lathe.
    3. Grinding the end of a tube squarely on my Homemade Metalworking Lathe.
    4. Grinder Brackets
    This grinder attachment works well for me to do finish work on lots of
    projects.
    I accept no liability for use of this project. You are responsible for any project you build.
    This project can also be viewed at "anglegrindermountbrackets.wordpress.com" or "HAND GRINDER MOUNT BRACKETS.wordpress.com"
    1. HAND GRINDER MOUNT BRACKETS-dsc01211.jpgHAND GRINDER MOUNT BRACKETS-dsc01212.jpg
    2. HAND GRINDER MOUNT BRACKETS-dsc01229.jpgHAND GRINDER MOUNT BRACKETS-dsc01230.jpgHAND GRINDER MOUNT BRACKETS-dsc01231.jpg
    3. HAND GRINDER MOUNT BRACKETS-dsc01243.jpgHAND GRINDER MOUNT BRACKETS-dsc01244.jpg
    4. HAND GRINDER MOUNT BRACKETS-dsc01235.jpgHAND GRINDER MOUNT BRACKETS-dsc01236.jpgHAND GRINDER MOUNT BRACKETS-dsc01237.jpg
  2. The Following 18 Users Say Thank You to paulk For This Useful Post:
    allenz (Oct 28, 2023), Andyt (Oct 30, 2018), bigtrev8xl (Nov 5, 2018), Canobi (Oct 29, 2018), dekeros (Oct 31, 2018), high-side (Jan 30, 2019), Jon (Oct 22, 2020), Ken Koch (Nov 5, 2018), LMMasterMariner (Oct 31, 2018), Moby Duck (Jan 26, 2019), mwmkravchenko (Oct 30, 2018), neilbourjaily (Oct 29, 2018), PJs (Oct 30, 2018), rossbotics (Oct 30, 2018), Seedtick (Oct 29, 2018), Shanty (Nov 4, 2018), Sleykin (Oct 29, 2018), Tule (Oct 30, 2018)
    Supporting Member Canobi's Avatar
    Mar 2016
    Shrewsbury, Shropshire (UK)
    Canobi's Tools
    Love the simplicty, I could do with one of these for an upcoming project (optical punch) so may have to borrow your idea.
    It's not the destination but the journey you take to get there that matters.
    Thanks paulk! We've added your Angle Grinder Mounting Bracket to our Grinding category,
    as well as to your builder page: paulk's Homemade Tools. Your receipt:
