Hi Captian
Having given a bit of thought about your setup, You could get a piece of tubing that telescopes inside your material and Mark out were the blade should come out Cut it at that point and then weld the telescoping piece inside one end and the other peice would slip on the telescoping piece.
then attach the welded end to the bandsaw table with a bolt through the square pipe as how you fixed it to the table.
Ill draw a plan and send it to you.
Cinders
Ps I hope you can understand my ramblings
