Results 1 to 7 of 7
Thread: Heat shrink joining square and round tubing - GIF
Hybrid View
    Heat shrink joining square and round tubing.
    HDPE pipe fusion machine - photo and video
    Friction welding drill pipe for oil exploration
    Pipe friction welding - GIF
    Polyurethane friction welder - GIF
  2. The Following 10 Users Say Thank You to Altair For This Useful Post:
    carloski (Jul 26, 2022), durrelltn (Mar 13, 2022), elk-a-holic (Mar 9, 2022), emu roo (Mar 5, 2026), flyfr8rs (Mar 13, 2022), johncg (Mar 9, 2022), mdhatter3 (Mar 8, 2022), Ralphxyz (Mar 9, 2022), Scotsman Hosie (Jul 3, 2022), Sleykin (Jun 28, 2022)
    square to round transition via drink bottle,,,,,,Hummm, could probably do this with gutter down spouts as well .
  4. The Following 6 Users Say Thank You to Frank S For This Useful Post:
    baja (Mar 13, 2022), cognitdiss (Apr 29, 2024), elk-a-holic (Mar 9, 2022), emu roo (Mar 5, 2026), mdhatter3 (Mar 8, 2022), Moby Duck (Mar 12, 2022)
    Aug 2012
    Australia
    desbromilow's Tools
    aircraft modellers do a similar trick where they make up a small wooden form of a cockpit window, then shrink the PET bottle over the top to make the "cockpit glass", and then cut out the bottom to release the wooden form.
    I've done similar to make ogive transitions for model rocketry.
    The only constraint you have is that the PET won't easily shrink to less than the original "cast" diameter. PET bottles are made from blanks which are approximately the diameter of the neck where the lid screws on, so it's difficult for them to shrink less than that.
  6. The Following User Says Thank You to desbromilow For This Useful Post:
    Dec 2017
    baja's Tools
    Quote Originally Posted by desbromilow View Post
    I have used liquid yeast for beer brewing and the containers used to be liter soda bottle blanks before they were blown up. Now they sell it in plastic containers somewhat similar to ketchup packets.
  8. The Following User Says Thank You to baja For This Useful Post:
    Dec 2016
    Ralphxyz's Tools
    How do you center things? Nice idea!
    Ralph
  10. The Following User Says Thank You to Ralphxyz For This Useful Post:
  11. #6
    Aug 2012
    Australia
    desbromilow's Tools
    Ralph
    As long as you are close, and you heat evenly, the surface tension of the shrinking plastic should centre the pieces for you - based on the concepts of equalising forces, and minimised surface area.
  12. The Following User Says Thank You to desbromilow For This Useful Post:
  13. #7
    Jul 2018
    Flora, MS
    Floradawg's Tools
    I didn't know you could shrink that. That's good to know.
  14. The Following User Says Thank You to Floradawg For This Useful Post:
