Thread: Heavy Duty Bench Top Tripod for Spotting Scope or Camera.
    jjr2001's Tools
    Light duty table top tripods are nice for the back pack but when I need stability at high magnifications I want a rigid tripod.
    I had a good tripod head from an old Vivitar tripod that was removed when I made my Gimbal Tripod Head.
    Homemade Gimbal Tripod Head - HomemadeTools.net
    All that was needed was an aluminum adapter for the base that would replicate the original Vivitar mount.
    Next was the new base. I wanted heavy and used some Hex Brass Stock.
    Three holes were drilled using an endmill at about a 5 degree angle. That is for the low position.
    Three more holes were drilled at about 15 degrees for the high position.
    The brass base is drilled in the center and tapped for 3/8 thread that matches the vivitar tripod head.
    Short length of 3/8 all thread to connect all the pieces.
    Legs are 1/2" drill rod and have a groove at one end for the locking screws.
    Heavy but no more shake..
    Attached Thumbnails Attached Thumbnails Heavy Duty Bench Top Tripod for Spotting Scope or Camera.-img_1402copy.jpg   Heavy Duty Bench Top Tripod for Spotting Scope or Camera.-img_1403-copy.jpg   Heavy Duty Bench Top Tripod for Spotting Scope or Camera.-img_1404-copy.jpg   Heavy Duty Bench Top Tripod for Spotting Scope or Camera.-img_1405-copy.jpg   Heavy Duty Bench Top Tripod for Spotting Scope or Camera.-img_1406-copy.jpg
  2. The Following 12 Users Say Thank You to jjr2001 For This Useful Post:
    DrByte (Jun 7, 2018), Guy Marsden (Apr 28, 2022), Harvey Melvin Richards (Dec 23, 2017), high-side (Jul 23, 2020), Jon (Dec 21, 2017), Paul Jones (May 26, 2018), PJs (Dec 21, 2017), rlm98253 (Dec 21, 2017), saguaro (Oct 23, 2024), Saltfever (Jul 15, 2020), Seedtick (Dec 21, 2017), willyC93 (Jul 3, 2018)
    Thanks jjr2001! We've added your Bench Top Tripod to our Photography and Videography category,
    Dec 2017
    NeiljohnUK's Tools
    Reminds me of some tripod bases I made at school 50 years ago! You might want to add some plastic balls or golf balls as feet to prevent surface marring as I did back then.
  5. The Following User Says Thank You to NeiljohnUK For This Useful Post:
    jjr2001 (Jan 15, 2024)
