Frank You are the man! Bob
Quote:
Originally Posted by
Frank S
Many years ago when I regularly worked on heavy equipment and trucks I owned a heavy duty transmission jack the other day a friend called me to ask if I could put a clutch and rear main seal in his Mack. I told him sure why not. So he said he would be passing through in a couple of weeks after I hung up the phone I remembered that I don't have a jack any more. No problem I'll Hire my neighbor who lives about a mile away to bring his over. Big problem his is busted he needs to have it repaired. I offered to rebuild the ram for him but he had already taken it to a shop where they have ordered the parts not sure when they will be in or when he will get his jack back. So I decided to just build one.
After looking around I pulled a couple of 4x4 1/4" sq tubes out of my usable scrap pile dug out 4 heavy duty casters 2 rigid and 2 swivel from my storage van then found an 8 ton engine hoist jack. Hauled a piece of 1/2" plate steel out of my scrap pile and 8 lengths of 1" pipe that at one time was a sprinkler system A few feet of 3/4" 1018 cold roll rod for the pivots shafts and a lenght of 1/14" chromed cylinder rod for the pivots and a few set collars that I made up previously and I was all set I had a heavy duty transmission jack the only thing left to do was cut drill and weld all of this together
Attachment 24157
Attachment 24158
Attachment 24159
Attachment 24160
After welding the 1 " pipes together to make the link arms I needed a weld jig to make sure the ends were parallel and matching lengths
so I already had 1 hole in the 1" thick table I used my mag drill to drill another turning the table into a welding fixture or jig
Attachment 24163
I mig welded the ends on by welding about an inch inside of the pipes filling with weld
Attachment 24165
After all the ends were welded on the link arms and cooled I reamed the bores using my #7 tap handle on the tang of the MT#3 shank of a 3/4"
Attachment 24166
Pre-assembled everything before welding
Attachment 24167
Just tacked together
Attachment 24168
Now a fully functional transmission jack
Attachment 24169
I used KBS rust blast to remove the surface rust and provide a pre paint primer surface
Attachment 24170
KBS rust blast leaves a zinc coating that can either be brushed off or left in place Since I was out of etching primer I opted to just rub off and loose residue and leave the rest to serve as a primer
Attachment 24171
Painted with KBS rust seal machinery gray
Attachment 24172
Another Classic by Frank. Excellent.
