Results 1 to 5 of 5
Thread: Heightening steel posts under a structure - GIF
    May 2024
    Heightening steel posts under a structure.
    1850s raising of Chicago buildings - image
    Raising a heavy post without machines - GIF
    Raising a large tank - GIF
    Raising a wind turbine - GIFs
    mr mikey (Jul 10, 2024), nova_robotics (Jul 10, 2024)
    hemmjo's Tools
    Want to see the jacks for that!!!
    You do, all of those darker support posts you see with hoses connected to them are long st5roke hyd. cylinders doing the lifting these will be anchored tot eh slab and if you watch the right side of the screen, you can see much larger columns also telescoping. Those are lifting and stabilizing as well. Judging from the men moving about, the scale of the building appears to being altered from about 10or 11 ft clearance to 15 or 16 ft
  5. The Following 6 Users Say Thank You to Frank S For This Useful Post:
    baja (Jul 10, 2024), drivermark (Jul 10, 2024), Floradawg (Jul 10, 2024), hemmjo (Jul 10, 2024), nova_robotics (Jul 10, 2024), that_other_guy (Jul 18, 2024)
    hemmjo's Tools
    Ah yes indeed, thanks..
    Mar 2018
    Hoosiersmoker's Tools
    That has to be a well balanced power supply too. They're all lifting at almost exactly the same rate.
    "The man who views the world at 50 the same as he did at 20 has wasted 30 years of his life."
    - Muhammad Ali
