Results 1 to 7 of 7
Thread: Helical milling clamps
    These are a copy of a clamp system more commonly found in Europe, but an interesting build anyway.
  2. The Following 12 Users Say Thank You to Occasional machinist For This Useful Post:
    allenz (Dec 29, 2023), blkadder (Dec 29, 2023), emu roo (Dec 1, 2025), Improvised DIY (Dec 21, 2023), Jon (Dec 20, 2023), mklotz (Dec 25, 2023), mr mikey (Dec 29, 2023), nova_robotics (Dec 20, 2023), Ralphxyz (Dec 29, 2023), rgsparber (Dec 22, 2023), rlm98253 (Dec 29, 2023), trevor_60_r (Dec 30, 2023)
    Sep 2018
    nova_robotics's Tools
    That's great. I've never seen that style of clamp before. I like that way better than the normal table clamps that I'm used to.
  4. The Following User Says Thank You to nova_robotics For This Useful Post:
    Thanks Occasional machinist! We've added your Helical Milling Clamps to our Clamps category,
    as well as to your builder page: Occasional machinist's Homemade Tools. Your receipt:
    Supporting Member Improvised DIY's Avatar
    Feb 2022
    Improvised DIY's Tools
    Very well executed and educational.
  8. The Following User Says Thank You to Improvised DIY For This Useful Post:
    Glad you enjoyed it.
    A friend of mine predicted that a lot of people would find this interesting as there is not much helical milling content out there. Judging from the response so far, he was right.
  10. The Following 2 Users Say Thank You to Occasional machinist For This Useful Post:
    emu roo (Dec 1, 2025), rgsparber (Dec 23, 2023)
  11. #6
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    This is a challenging and fun project.
    In his last example, the regular step clamp faces the work and the bottom collides with it. One workaround is to use the large triangle step block plus a small triangle step block. Place the small step block, up-side-down, on the larger step block. You will have a movable horizontal surface. Face the larger step block at 90 degrees from the stock. Then rest the tail of the hold-down clamp on the small step block. Secure with a hold-down bolt.
    Boring, but it works with the available parts in my hold-down kit.
    Rick
    Rick
  12. The Following 3 Users Say Thank You to rgsparber For This Useful Post:
    emu roo (Dec 1, 2025), Philip Davies (Dec 29, 2023), trevor_60_r (Dec 30, 2023)
  13. #7
    I've used a small step block on large and some times that has gotten me out of trouble. These were made because I wanted to try them out (and I always find the 'how do you make them' question interesting), and I have a number of work surfaces (rotary tables for example) that haven't got the space for a more conventional clamping arrangement
  14. The Following 2 Users Say Thank You to Occasional machinist For This Useful Post:
    emu roo (Dec 1, 2025), phred (Dec 29, 2023)
