Results 1 to 6 of 6
Thread: help construction frame pole tractor
    Supporting Member forgiaro's Avatar
    Apr 2014
    italia
    forgiaro's Tools
    Question help construction frame pole tractor
    hello I should make a frame and the crane boom to hoist gin pole to be installed on tractor height under hook 12 feet reach 2 tons, could you give me tips thanks
    help construction frame pole tractor-265131d1159295401-3pt-hitch-engine-hoist-cimg0205.jpg
    help construction frame pole tractor-265132d1159295401-3pt-hitch-engine-hoist-cimg0206.jpg
    help construction frame pole tractor-265133d1159295401-3pt-hitch-engine-hoist-cimg0207.jpg
    3PT Hitch Engine Hoist - Pirate4x4.Com : 4x4 and Off-Road Forum
    Attached Thumbnails Attached Thumbnails help construction frame pole tractor-trattore.jpg   help construction frame pole tractor-trattore-2.jpg
    Che tu creda di farcela o di non farcela avrai comunque ragione
  2. The Following 2 Users Say Thank You to forgiaro For This Useful Post:
    Jon (Oct 10, 2015), kbalch (Oct 10, 2015)
    Apr 2014
    italia
    forgiaro's Tools
    You have any suggestions? someone built a homemade crane could give me constructive advice thanks
    forgiaro; Sir if you desire to build your own crane boom for your tractor. Some pictures of the tractor you want to build the boom to fit would be helpful.
    Do you want to mount it to the front end or off the rear?
    will you also be using a winch or hoist or just raise the boom tip for lifting?
    If you can give us an idea of what you need to lift and some pictures of your tractor you want to use, that information will help someone direct you better to accomplish your task.
    I for one could 3d cad design one for you providing I had some more information
    Apr 2014
    italia
    forgiaro's Tools
    I want to mount the rear to better link to the frame and so the engine acts as a counterweight ballast,
    I do not have a winch momentarily on the tractor could use a manual hoist
    help construction frame pole tractor-06510a0666b5a8c4bf1c6bddf88b781c_orig.jpg
    Fiat 466 DT
    help construction frame pole tractor-7759532dc277b46886ea0aa768f54f29_orig.jpg
    help construction frame pole tractor-ac703c21d580bd757c1c0b4cfb6bb210_orig.jpg
    I will have to try and pull up a build or spech sheet on your tractor to know the possible suitable mounting locations and the loading limits of the locations. it is one thing to just toss together some apparatus and mount it to a tractor quite another to construct something which will have functionality be safe and not a danger to damaging the tractor.
    Apr 2014
    italia
    forgiaro's Tools
