Page 3 of 3 FirstFirst 1 2 3
Results 21 to 25 of 25
Thread: Help needed, Craftsman wood planer.
  1. #21
    I get it Tony, that it will be used occasionally and likely on softer wood for an indoor green house. Also get it about the correlation to the hand planer speeds and ratings. My point about the bearings should have been clarified.
    Just because a bearing is rated at some speed based on being sealed or not and what type of lubricant doesn't mean the rest of the system is rated for that maximum or under load because bearings are off the shelf items to fit a myriad of purposes. Additionally the Static and Dynamic loads play into that rating system. Not sure how I would rate the bearing loading of hand fed wood on a Jointer but think it may be higher than expected...again guessing on wood quality, but do know my 6" old iron gets with the program depending on depth of cut and will slow down slightly and get a trashier finish if I get too aggressive.
    An example of bearing rating is my 1950 Craftsman/King Seeley Drill press uses 6202 and 6205 bearings...basically all 6200 series are rated at 13k-24k rpm with a static load of 3750N and Dynamic of 7800N (plenty for a drill press). Mine were rubber sealed, original and 65 years old, therefore rated at 13k, 65 years ago. It came with a middle pulley system that would allow speeds from 310-9835, meaning in new condition they would run at ~75% max...plenty of safety factor from an engineering standpoint, however the 5/8" spindle if out of round or bowed or the taper chuck wasn't true would likely would play havoc at those speeds and be worrisome...to me. Also the RO/balance of the 3-5way pulleys, one a splined pulley on the spindle...belts, motor, etc...it's a system. If I wanted to use circuit board drills occasionally I would probably be ok with that...if the RO is within reason and very light loads. Soooo your 78% may be valid if the rest of the system will handle it, but have no clue what the system speed originally was that I could find.
    I too have often wondered about this topic for wood working and would love to understand it better. Then I realize most wood working is esthetic and tolerances of 1/16" and finishes in the 125-250 range or greater, instead of metal working to thousands or tenths and finish down to 8 that we have worked with for many years. Inquiring minds!! Hopefully someone can enlighten us all.
    Had another thought if you have one laying around. Depending on motor type, perhaps put a single phase VFD on it and set your pulley/belt system up to match that 12K speed and experiment with it. If the VFD can be set up for constant torque it would be good...just another thought?
    Either way good luck in what ever direction you choose and do look forward to seeing what you come up with. Hopefully it doesn't discourage your motivation to get this done so you can tackle the green house. ~¿@
    PJ
  2. The Following User Says Thank You to PJs For This Useful Post:
    tonyfoale (Mar 11, 2018)
  3. #22
    Indoor greenhouse? That's a new one on me. No, it will be outdoors.
    Hopefully it doesn't discourage your motivation.
    Never.
  4. The Following User Says Thank You to tonyfoale For This Useful Post:
    PJs (Mar 12, 2018)
  5. #23
    At this point in time I am totally undecided whether to run the thing around 6,000 or closer to 12,000 rpm. This will never be a highly used tool for me and I only want to make it once, so the safe way I guess, would be to opt for the lower speed range but the hot rodder in me is reluctant to accept that without some real data. Getting real data seems to be much harder than I expected. I have to decide soon because I promised to build a green house for her indoors. I have tools to do that job without the planer but it seemed to be the right motivation to get a tool going that I have had gathering dust for close to 10 years.
    Guess I misunderstood. Looking forward to what you come up with.
    PJ
  6. #24
    I have noticed that many machinists who make the transition to woodworking have trouble with the lack of "specifics" when it comes to working with wood. Many fine woodworkers do not mess with minute details or speeds and feeds, they just do what works. Wood is much more forgiving that metal.
    I turned to the American Machinists Handbook, by Colvin and Stanley, McGraw-Hill for information regarding your question. First printed in 1908, I have the 7th edition, 1940, that was my Dad's. It is well worn, has masking tape and a rubber band holding it together. It had a special place in his machinists tool box, in the top along side his sine bar, and 1,2,3 blocks. He was a machinist with the Curtis-Wright aircraft company, then North American Aviation, then North American Rockwell, then Rockwell International, as the companies merged over the years.
    There are only a couple of references in the AMH regard to wood. Attached is the table of contents, Speed for Drilling p. 126, Turning speeds p. 898, and weights of various kinds p. 1104-1105. (Note that the Table of Contents is incorrect. Turning speeds is in reality located on Page 999) Perhaps you can use these values to determine a reasonable speed for your purposes, as other materials are also listed in the drill speed table. The percent of difference between materials for drilling should be about the same for "milling" as you will be doing with your planer/jointer.
    Attached are photos of relevant pages.
    Attached Files Attached Files
  7. The Following User Says Thank You to hemmjo For This Useful Post:
    PJs (Mar 12, 2018)
  8. #25
    Thank hemmjo, I never thought of the Machinist's Handbook, I have the 17th and 26th editions.
