Results 1 to 8 of 8
Thread: HF Welder cart mod 3
    Jul 2014
    San DIEGO, California
    Captainleeward's Tools
    HF Welder cart mod 3 Electrical box receptacle quick release plug.
    HF Welder cart mod  3-new-zealand-2018-016.jpgHF Welder cart mod  3-new-zealand-2018-017.jpg
  2. #2
    Frank S's Avatar
    I like having the ability of storing the power cord off of the cart. I'm just not fond of having a double male cord which according to your pictures this might be the way you went with it. here is a picture of a couple of inlet receptacles which allow for the use of a standard design male female cord.
    A Nema L14-30 More than enough amp cap for the little welder
  3. The Following User Says Thank You to Frank S For This Useful Post:
    metric_taper (09-21-2019)
    Jul 2014
    Hi Frank, Well it all started when i had this generator that had a female 220 volt outlet then I bought a 20 ft extension cord, then I wanted to adapt it to the welder.
    So I put a big red light on the power box and never turned it on before I plugged it in . and so it is now.
    Frank S's Avatar
    Quote Originally Posted by Captainleeward View Post
    I know the feeling I had a generator set up that way for a while at a place I lived. But one day I needed the cord for something else and changed 1 end then instead of needing to change it back every time I wanted to use the generator as auxiliary power I bought one of the recessed male connectors to install at the house problem solved and the risk of someone else not knowing the double male cord. I left the female receptacle on the house as well giving me double use out of my cord.
    Dec 2017
    Suicide Cord.
    This is a direct violation of National Electrical Code Section 406.6 (A) and (B). Commonly called "suicide cords". Remember you will be held personally libel if it causes a fire or someone receives a shock. I would deem this not worth the risk. Other methods to avoid this have been shown by Frank S. Worth the cost.
  7. The Following User Says Thank You to BLLG For This Useful Post:
    Thanks Captainleeward! We've added your Welder Cart Electrical Outlet to our Electrical category,
  9. #7
    Jul 2014
    OK I will change the system for the better.
  10. #8
    Feb 2015
    Manitoba Man's Tools
    Quote Originally Posted by BLLG View Post
    I hear you, that bright short cut might be your last idea.
    Post your reply!
    Join 41,949 of us and get our 173 Must Read Homemade Tools eBook free.
