Results 1 to 5 of 5
Thread: High-pressure water blasting a car - GIF
Hybrid View
    May 2024
    High-pressure water blasting a car.
    Abrasive blasting paint off a door - GIF
    Dry ice blasting a chassis - GIF
    Dry ice blasting paint - GIF
    clydeman (Jun 1, 2025), emu roo (May 31, 2025)
    A fine powdery aggerate is also generally used in the water, one thing is whatever has been wet blasted clean must be dried with hot dry pressurized air and sprayed with a thin primer as soon as it is dry or the next day it will be brown with oxidation.
    Supporting Member bob_3000's Avatar
    Aug 2020
    It was probably dipped in solvent before the spraying.
  5. The Following User Says Thank You to bob_3000 For This Useful Post:
    Karl_H (May 31, 2025)
    hemmjo's Tools
    Has t be more to it that just water and lots of pressure.
    Lake Tahoe
    IntheGroove's Tools
    Paint remover was added first...
