Thread: High-pressure water jet for unclogging pipes - GIF
    May 2024
    High-pressure water jet for unclogging pipes.
    Cleaning out a clogged restaurant grease trap - GIF
    Clearing a clogged sewer - GIF
    Removing tree root clogging pipe - GIF
    Worker unclogging steel mill pipe - GIF
    nova_robotics (Jan 2, 2025)
    nova_robotics's Tools
    That's excellent. I could use that for a job.
    You need a BIG pressure washer to run that washing head!!
    I have small one that will fit into a 3/4" ID straight pipe. It is flexible enough to fit through a 1 1/2" sink trap. The largest clog I have cleared with it was in a 4" corrugated drain pipe that had filled with mud for about 10' My little pressure washed only pumps 2 gpm at 2500 PSI.
    This is what I have. https://www.cloghog.com/
    I have no affiliation with this, but it works very well. The only drawback is the jets are so small, they clog easily. You HAVE to make sure your pressure washer hose is clean inside.
  5. The Following User Says Thank You to hemmjo For This Useful Post:
    Sep 2013
    Karl_H's Tools
    Carsten over on the German Kempinger Drain channel calls that "The Flounder."
