Page 57 of 59 FirstFirst ... 7 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 LastLast
Results 561 to 570 of 585
Thread: High-quality black-and-white photographs of large old machines and tools
  1. #561
    Sep 2012
    Hinchinbrook QLD
    Based on the size of their equipment its probably where they store their spanners
  2. #562
    Supporting Member Isambard's Avatar
    Aug 2019
    Hawke's Bay, New Zealand
    It appears as if 62" was the biggest diameter for solid blades, bigger were of the inserted variety. The motor on a 36" blade was 50 hp so they got to be big machines.
    I think your estimate to be about right, at 4'.
  3. The Following User Says Thank You to Isambard For This Useful Post:
    cmarlow (Sep 26, 2021)
  4. #563
    Gang drill. Pittsburgh and Lake Erie Railroad Company. July, 1904.
    Fullsize image: https://s3-us-west-1.amazonaws.com/h...l_fullsize.jpg
  5. The Following 3 Users Say Thank You to Jon For This Useful Post:
    cmarlow (Sep 26, 2021), jimfols (Sep 26, 2021), Toolmaker51 (Sep 28, 2021)
  6. #564
    Aug 2019
    Bement, Miles & Co of Philadelphia, machine.
  7. #565
    Apr 2016
    i wonder what the gang was drilling working on the railroad all the live long day. ...perhaps a tick tok's grand maws grand maws?
  8. #566
    Oct 2018
    There are 3 rods and two arms on the horses in front of the drill table and one more of the arms still sitting on the drill table. Anybody have any idea of what they were for?
    Also, I see a pretty impressive set of change gears on top of those drills, almost like the back gear setup on a lathe. Are they to control the feed speed of the drill?
  9. #567
    Aug 2019
    Due to long term renovations, storage is chaotic. Man alone does not help. :-(
    Anyway, tracked down a Bement cat that I have of era and the following is the
    specs of the machine above:
    Two-Spindle Locomotive Connecting Rod Drilling Machine:
    Designed for drilling at one time both ends of locomotive connecting and parallel rods.
    Distance between centers 10 feet max - 3 feet min.
    Power - Will drill 3-1/2" hole in solid material and bore a 9 inch hole. IMPRESSIVE!
    Spindles are independently driven, having 4 speeds, & 3 feeds through a distance of 15-1/2",
    Quick return motion, lever counterbalance and lateral adjustment on cross-slide by
    rack & pinion.
    Each spindle is adjustable vertically. two lube pumps.
    Countershafts & spanners thrown in.
  10. The Following 2 Users Say Thank You to Isambard For This Useful Post:
    12bolts (Sep 30, 2021), cmarlow (Sep 30, 2021)
  11. #568
    Oct 2018
    I look at these picture and my sense of scale is destroyed.
  12. #569
    1959 Milwaukee-Matic II, the first machine with a tool changer.
    Fullsize image: https://s3-us-west-1.amazonaws.com/h...I_fullsize.jpg
  13. The Following 2 Users Say Thank You to Jon For This Useful Post:
    jimfols (Oct 3, 2021), Toolmaker51 (Oct 3, 2021)
  14. #570
    And a small apartment...or large closet.
There are currently 8 users browsing this thread. (0 members and 8 guests)
