Results 1 to 4 of 4
Thread: Hold down clamps for T-slots
    Supporting Member morsa's Avatar
    morsa's Tools
    A while ago, I needed some hold down clamps for the homemade T-slots at the drill press table; eventually, I had three different versions, and they all worked well:
    1- First attempt was bending and gluing thin strips of wood
    2- Second approach was to cut the shape in plywood
    3- The third attempt was cutting the shape in solid wood and adding a pivoting dowel
    4- A variant of the previous model consisted of making the pivot with aluminum
    Either of the models are easy to make, and are an alternative to commercial hold down clamps; in addition, you could make them in two or three different lengths.
    Regards, morsa.
  2. The Following 3 Users Say Thank You to morsa For This Useful Post:
    Frank S (Nov 14, 2016), Paul Jones (Nov 17, 2016), PJs (Nov 15, 2016)
    Walney Col's Avatar
    Jul 2014
    I'm a big fan of quick release clamps and have found cycle seat clamps and wheel skewers to be invaluable for use in jigs and fixtures.
    Col.
  4. The Following 2 Users Say Thank You to Walney Col For This Useful Post:
    morsa's Tools
    Thanks, Walney Col. That's a great idea. They are called cam clamps, and you are right, they are very useful in jigs. There are commercial items (i.e. Cam Clamps - Rockler Woodworking Tools), but of course you can reuse clamps from discarded bikes. Even in these hold down clamps, you could use a cam clamp instead of the threaded knob.
    I have a pair of these discarded cam clamps and I will try to find them an application.
  6. The Following User Says Thank You to morsa For This Useful Post:
    PJs (Nov 15, 2016)
    Thanks morsa! We've added your Hold Down Clamp to our Clamps category,
    as well as to your builder page: morsa's Homemade Tools. Your receipt:
