Results 1 to 10 of 10
Thread: Home made machine for mixing components and pouring foam polyurethane
    Supporting Member Mehanol's Avatar
    Oct 2017
    Malahovka
    Mehanol's Tools
  2. The Following 4 Users Say Thank You to Mehanol For This Useful Post:
    Loose Ctrl (Oct 12, 2017), Seedtick (Oct 11, 2017), stuffucanmake (Dec 26, 2018), thevillageinn (Oct 22, 2017)
    Oct 2017
    Malahovka
    Mehanol's Tools
    Home made machine for mixing components and pouring foam polyurethane-ppu2.jpgHome made machine for mixing components and pouring foam polyurethane-ppu3.jpgHome made machine for mixing components and pouring foam polyurethane-ppu1.jpg
  4. The Following 2 Users Say Thank You to Mehanol For This Useful Post:
    Thanks Mehanol! We've added your Foam Mixing and Spraying Machine to our Miscellaneous category,
    as well as to your builder page: Mehanol's Homemade Tools. Your receipt:
    Dec 2016
    Ralphxyz's Tools
    Waste of time never see the final product, too bad, I was interested.
    Ralph
    Oct 2017
    Malahovka
    Mehanol's Tools
    Yes, you need to show the finished product
    Home made machine for mixing components and pouring foam polyurethane-cimg0867.jpgHome made machine for mixing components and pouring foam polyurethane-cimg0862.jpgHome made machine for mixing components and pouring foam polyurethane-kreslo_mehanol7.jpgHome made machine for mixing components and pouring foam polyurethane-kreslo_mehanol4.jpgHome made machine for mixing components and pouring foam polyurethane-anna.jpg
    Attached Thumbnails Attached Thumbnails Home made machine for mixing components and pouring foam polyurethane-kreslo_gnesdo_2-1.jpg
  8. The Following User Says Thank You to Mehanol For This Useful Post:
    Jon (Oct 12, 2017)
    Dec 2016
    Ralphxyz's Tools
    Thanks, now that is more interesting.
    Ralph
  10. #7
    Nov 2018
    Hello everyone,
    I find this very interesting since I was planning on building one myself. I wish that I could watch the video but Youtube gives me the "This video is unavailable on this device" message, no mater which device I try to watch it on.
    I am interested in the output and if the gravity feed is sufficient (Bertolini pumps usually need a few psi at the input). I also see that no static mixer were used...I wouldn't have thought so.
    Regards to all!
    MiCam
  11. #8
    Can confirm, I'm getting the same error in multiple browsers, even when viewing the video un-embedded on youtube.com. Have never seen that error before.
  12. #9
    Oct 2017
    Malahovka
    Mehanol's Tools
    At the entrance to the pump 1.5 atmospheres
    Corrosion was only in the mixer, in one (Poly) of two nozzles (from the truck), the needle valve rusted, it changed every 2-3 months.
    No more has been replaced in the system.
    The system works 8 years. The system was turned on every 2 weeks. All this time, the system was charged with Iso and Poly components.
    Google translation
  13. The Following User Says Thank You to Mehanol For This Useful Post:
    Jon (Nov 13, 2018)
  14. #10
    Nov 2018
    Many thanks for all the info.
    These will be very useful in the design of my project.
