Homemade Chain
Chain is probably one of the most under-rated and overlooked tools out there but it sure does come in handy more often than not! Here, I demonstrate how to forge chain. Now, in the video, I only make 3 links, and they are 5/16" round stock, but you can use the same process to make your chain as long and links as big as what you need. Since my links are fairly small, I was able to get each link done with 3 welding heats, but on larger stock, say half inch or more, it's a good idea to do at least 5 welding heats for structural integrity and load-bearing capacity.
https://youtu.be/kMqDm4deZJc
Thanks Frontier Forge! We've added your Chain to our Forging and Casting category,
as well as to your builder page: Frontier Forge's Homemade Tools. Your receipt:
<div id="blocks">
<div class="block b1 pngfix">
<div class="bimg">
<div>
<a href="http://www.homemadetools.net/homemade-chain">
<img src="/uploads/219187/homemade-chain.jpeg"/>
</a>
</div>
</div>
<div class="title">
<a href="http://www.homemadetools.net/homemade-chain">Chain</a>
<span> by <a href="http://www.homemadetools.net/builder/Frontier+Forge">Frontier Forge</a></span>
</div>
<div class="tags">tags:
<a href='http://www.homemadetools.net/tag/chain'>chain</a> </div>
</div>
</div>
</div>
