https://youtu.be/DdPwRQAf4Sg
I figure out that i wasn't pumping enough oil because the pedal was too low, i extended up the pedal degree to pump the oil as it should before it touches the floor and now it works normally.
Thanks Metalgeria! We've added your Hydraulic Scissor Lift Table to our Motorcycle Lifts, Stands, and Dollies category,
as well as to your builder page: Metalgeria's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-hydraulic-scissor-lift-table"> <img src="/uploads/257171/homemade-hydraulic-scissor-lift-table.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-hydraulic-scissor-lift-table">Hydraulic Scissor Lift Table</a> <span> by <a href="https://www.homemadetools.net/builder/Metalgeria">Metalgeria</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/motorcycle'>motorcycle</a>, <a href='https://www.homemadetools.net/tag/lifting'>lifting</a> </div> </div> </div> </div>
