Results 1 to 10 of 12
Thread: Homemade Lathe Chuck
    Machining 4 ALL
    machining 4 all's Avatar
    May 2020
    machining 4 all's Tools
  2. The Following 9 Users Say Thank You to machining 4 all For This Useful Post:
    Canyonman44 (10-20-2020), Dimsa (10-20-2020), emu roo (10-21-2020), Jon (10-19-2020), lsb (10-20-2020), mklotz (10-20-2020), mwmkravchenko (10-21-2020), nova_robotics (10-20-2020), rlm98253 (10-20-2020)
    Thanks machining 4 all! We've added your Lathe Chuck to our Lathe Accessories category,
    as well as to your builder page: machining 4 all's Homemade Tools. Your receipt:
    Sep 2018
    nova_robotics's Tools
    That's a nice low profile chuck. A hole in the middle would be handy.
    Dec 2016
    Ralphxyz's Tools
    Is everything Aluminium?
    Ralph
    Machining 4 ALL
    May 2020
    I chose not to drill a central hole. If you need it, it's easy to do. Thank you nova_robotics!
    Machining 4 ALL
    May 2020
    The material is recycled, but I took a sample from the metallurgy laboratory. Preliminary analysis indicates that it is SAE 4140 steel. Thank you Ralphxyz!
  8. #7
    Dec 2016
    Ralphxyz's Tools
    Thanks, is that just the plate or also the jaws?
    Ralph
  9. #8
    Machining 4 ALL
    May 2020
    In this project they are both in SAE 4140, but the plate could be another material (SAE 1020, cast iron, etc). The jaws could also be of another material, as long as it acquires temper. Thank you Ralphxyz!
  10. #9
    Dec 2016
    Ralphxyz's Tools
    Thanks, I wondered about the jaws, seems like if you did not set them as you did in the video that you could easily distort them if they were not hardenable steel.
    I really like the whole concept and have it on my list, if I can get suitable material cheap.
    Ralph
  11. #10
    Machining 4 ALL
    May 2020
    I use this plate for lighter services, however, you can reinforce the thickness of the jaws and increase the diameter of the screws as needed. I searched the internet for a model of jaws to serve as an idea, but I didn't find anything simple. So, I thought about this model, which was easy to build. Thank you Ralphxyz!
