Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 37
Thread: Homemade Lathe Headstock EXTERNAL Gearbox
    Supporting Member LMMasterMariner's Avatar
    Jan 2016
    Dubrovnik - Croatia
    LMMasterMariner's Tools
    Great job I might have only one suggestion
    I have used those adjustable pillow block bearing several times in the past. I found that in time no matter how Tight I thought I had them they would move just enough to cause a miss match My solution was to drill and tap a small piece of metal then weld one on each side to the adjustment then use a grub screw to hold the housing in place. It is a lot of work having to use two grubs on each bearing since you have 8 of them but it may pay off in the long run.
    Again great job
    Many thanks for the comments and suggestion. I noticed that also, but I thought that I didn' tighten them enough. Will do as suggested. Thanks again.
    That is indeed a very impressive project!!!!
    As I was reading through the posts and comments, I have to share that this line in one of your responses really made me laugh...."Recirculating oil pump would be very nice addition to this project, but I wanted to make it simple."
    These words specifically, "....but I wanted to make it simple.", really tickled my funny bone!!!! I am not positive but I think you flew past (or perhaps sailed in your case) simple long before you even started collecting all of the gears, and bearings, and racks, and keys, and oil sight glass, and bolts, and etc....
    I hope you get my perspective on this!!
    Awesome,
    John
  3. #13
    Thanks LMMasterMariner! We've added your External Lathe Gearbox to our Lathes category,
    as well as to your builder page: LMMasterMariner's Homemade Tools. Your receipt:
    LMMasterMariner (May 2, 2018)
  5. #14
    Berkshire UK
    thehomeengineer's Tools
    Hi LMMasterMariner
    Great build and the video was easy watching and interesting. Got my vote for tool of the week this is an exceptional add-on to your lathe and I congratulate you on your design and workmanship.
    First class.
    The Home Engineer
  6. The Following User Says Thank You to thehomeengineer For This Useful Post:
  7. #15
    Jan 2016
    Dubrovnik - Croatia
    Awesome,
    John
    couple of ideas which I abandoned in order to make it simple:
    12 speeds instead of 18 speeds
    different selector handles and detents. simply bought three M18 bolts and nuts and made different, much simpler detent mechanism, as I knew that I wouldn't have time to complete it as originally planned.
    couple of drawings attached.
    Attached Thumbnails Attached Thumbnails Homemade Lathe Headstock EXTERNAL Gearbox-scr2.jpg   Homemade Lathe Headstock EXTERNAL Gearbox-18-speed-02.jpg   Homemade Lathe Headstock EXTERNAL Gearbox-selector.jpg
  8. The Following 4 Users Say Thank You to LMMasterMariner For This Useful Post:
    olderdan (May 2, 2018), Paul Jones (May 2, 2018), PJs (May 2, 2018), Toolmaker51 (May 5, 2018)
  9. #16
    Apr 2012
    NorCal
    Saltfever's Tools
    Wow! Excellent presentation (thank you) and nicely engineered. Definitely Tool-of-the-week candidate! Was that disk brake OEM or did you add it?
  10. #17
    Jan 2016
    Dubrovnik - Croatia
    More about disk brake can be found at http://www.homemadetools.net/forum/l...ck-brake-61437 and http://www.homemadetools.net/forum/l...-fixture-61693
    Best regards
    LMMasterMariner
  11. #18
    Congratulations LMMasterMariner - your External Lathe Gearbox is the Homemade Tool of the Week!
    Multiple very nice tools this week, but this impressive build was a rarity on this forum: a clear winner.
    Screwhead Chuck by Christophe Mineau
    QCTP Rocker Tool Posts by jjr2001
    Simplified Bore Measurement Method by mklotz
    Digital Air Pressure Controller by chy_farm
    Double Disc Sander by Bellevue Woodshop
    Rivet Snap Tool by thehomeengineer
    Surface Gauge by CookieCrunch
    Cable Anchor Belt Clip by rgsparber
    Compound Slide Auto Feed by Christophe Mineau
    Scribe, Finger Plate, and Tap Follower by CookieCrunch
    Chuck Depth Stop by Christophe Mineau
    Braii Starter by garage nut
    Tiny Boring Bar by Christophe Mineau
    Rear Tool Post Spacer by jjr2001
    Rocker and Post Construction Method by Toolmaker51
    SDS Drill Adaptor by Rorschach
    Cherry Picker Modification by Viny
    Boring Bar Tool Post by jjr2001
    Extended Drill Bit by Christophe Mineau
    LMMasterMariner - you'll be receiving a $25 online gift card, in your choice of Amazon, PayPal, or bitcoin. Please PM me your current email address and gift card choice and I'll get it sent over right away.
    More importantly, this is your 5th Homemade Tool of the Week win! I've just added the silver wrench-on-pedestal graphic to the awards showcase in your postbit, visible underneath your avatar.
    Great job, and you're in excellent company joining these other 5-time winners: rossbotics, Christophe Mineau, Brendon, mklotz, Vyacheslav.Nevolya, brianhw, Tuomas, olderdan, tonyfoale.
    Here are all of your wins. Congrats again
  12. The Following 6 Users Say Thank You to Jon For This Useful Post:
    Captainleeward (May 4, 2018), Frank S (May 4, 2018), LMMasterMariner (May 4, 2018), olderdan (May 4, 2018), PJs (May 7, 2018), rossbotics (May 4, 2018)
  13. #19
    And most deserving of the award
  14. The Following User Says Thank You to Frank S For This Useful Post:
  15. #20
    Dec 2013
    Florida
    rossbotics's Tools
    Well deserved, congratulations
    Doug
    Comments are always welcome
    Doug
  16. The Following 3 Users Say Thank You to rossbotics For This Useful Post:
    Captainleeward (May 4, 2018), LMMasterMariner (May 4, 2018), PJs (May 7, 2018)
