If you use a document shredder especially one that has a chopping feature as well the time to turn the paper into pulp will be greatly reduced.
Another couple of things that can be done is to construct a much smaller diameter press like around 1" in diameter then mix a fine pulp mixture up and stir in a small amount of steel wool and magnesium filings press as much water out as possible then place the pulp sticks to dry After they are good and dry break them into 2 to 4 inch long sticks then dip them in melted wax store several sticks in a plastic freezer bag when going camping or needing a quick fire starter source you can break one apart and light it the intense heat it will give off will get your camp fire going quickly
