Hello Guys!
Today I finished my homemade sheet metal brake.
I used a steel corner 120cm with 50mm x 5mm
M20 & M16 threaded rods with nuts
2 adapters 1/2 ''
Ø 26 round tube
Ø 18 hinges
https://youtu.be/2-VkDRt5AoQ
Hello Guys!
2 adapters 1/2 ''
Ø 26 round tube
Ø 18 hinges
Very nice brake. From 10:08 - 10:20, you are braking a pan. I am curious how did you bend the ends, without crushing the previously bent sides?
Thanks PowerMk! We've added your Brake to our Brakes and Presses category,
as well as to your builder page: PowerMk's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-brake-6"> <img src="/uploads/229398/homemade-brake-6.png"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-brake-6">Brake</a> <span> by <a href="https://www.homemadetools.net/builder/PowerMk">PowerMk</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/brake'>brake</a> </div> </div> </div> </div>
