How to make Softbox Light using LED Ceiling Lights 230V https://youtu.be/UCukS0OrgkQ
Great idea! I plan to make one.
Thanks,
Rick
Great post and build for cheap and cheerful costs. 6500k temp is a good starting point but have found through experience that around 5500-6000k is a more natural daylight white. What was the filter material you used? Looked like frosted acetate. Please Let us know how they hold up to the heat. Minor Tip: if you put them up higher, pointing them more straight down you will reduce the double shadows.
Thanks for sharing a good build with us!
PJ
Thanks Lahis! We've added your Softbox Lights to our Photography and Videography category,
as well as to your builder page: Lahis's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="http://www.homemadetools.net/homemade-softbox-lights"> <img src="/uploads/219310/homemade-softbox-lights.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="http://www.homemadetools.net/homemade-softbox-lights">Softbox Lights</a> <span> by <a href="http://www.homemadetools.net/builder/Lahis">Lahis</a></span> </div> <div class="tags">tags: <a href='http://www.homemadetools.net/tag/light'>light</a>, <a href='http://www.homemadetools.net/tag/photography'>photography</a> </div> </div> </div> </div>
