Results 1 to 10 of 17
Thread: Homemade surface grinder
    Dec 2014
    Sheridan, Montana
    turntable's Tools
    Hi guys; here is my homemade surface grinder. made from Makita chop saw. works very well. in the pic was setting up to grind one of those so called precision machined angle plates from across the pond. it was off on all sides as much as .008. after grinding it is square within 1/10. not bad for a cheap grinder. now I will lap it to perfection.Homemade surface grinder-001.jpgHomemade surface grinder-002.jpgHomemade surface grinder-003.jpg
  2. The Following 35 Users Say Thank You to turntable For This Useful Post:
    airwright (Aug 19, 2025), almarghi (Sep 25, 2018), anthonyget (Jul 10, 2024), Arcadia (Apr 25, 2017), benkeller3 (Sep 25, 2018), bigtrev8xl (May 21, 2018), bimmer1980 (Jan 13, 2018), BrianW (Nov 29, 2018), Canobi (May 20, 2018), Canyonman44 (Jan 6, 2025), davidhoneybadger (May 20, 2018), Dorn (May 21, 2018), emu roo (Jul 9, 2024), freddo4 (Jul 11, 2024), goonergord (Jul 9, 2024), HUMARIA (Jul 10, 2020), Jon (Nov 12, 2015), JRock (May 20, 2018), kbalch (Nov 13, 2015), Kevic (Jan 14, 2018), mr mikey (Jul 9, 2024), mudnducs (Feb 1, 2016), mwmkravchenko (Jul 11, 2020), NortonDommi (May 5, 2020), olderdan (Jan 14, 2018), ozylee (Feb 17, 2024), Paul Jones (Nov 13, 2015), PJs (Nov 13, 2015), Ralphxyz (Jan 3, 2024), rgsparber (Jan 13, 2018), rlmck111 (Jul 9, 2024), stingraygs (Nov 13, 2015), tonyfoale (Dec 19, 2016), Toolmaker51 (Dec 25, 2016), tooly (Oct 16, 2022)
    Thanks turntable! We've added your Surface Grinder to our Grinding category, as well as to your builder page: turntable's Homemade Tools. Your receipt:
    turntable (Nov 13, 2015)
    Mar 2012
    very slick idea. Where did you source the grinding wheel?
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    Really Nice build, Turntable! Like the dressing rig too! Where does the air come from on the cooling line?
    Mark Twain
    Supporting Member Ed ke6bnl's Avatar
    Mar 2012
    So. California high desert
    Ed ke6bnl's Tools
    nice, is it hard to to set up? now you need a mag chuck
    Dec 2014
    Sheridan, Montana
    turntable's Tools
    Hi Dave; The wheel was purchased from Enco, it's a regular surface grinding wheel (46H 7x1/2x1.250). Made a spacer to mate wheel to arbor.
  9. #7
    Dec 2014
    Sheridan, Montana
    turntable's Tools
    Thanks Ed; It takes about 5 minutes to set up, Just slide the top in a 7/8 collet, hook the side arm on and square it up. already have a mag chuck, small 6x12, so far has been big enough for what I do.
  10. #8
    Dec 2014
    Sheridan, Montana
    turntable's Tools
    Thanks PJ; The dressing fixture was made out of the hand grip of an old compound bow I found at the local land fill. yes, I'm a big scrounge. There is air and coolint supply on left of machine. can flood part, mist it or just air.
  11. The Following User Says Thank You to turntable For This Useful Post:
    PJs (Nov 15, 2015)
  12. #9
    Dec 2015
    Reading, Berks, UK
    Philip Davies's Tools
    You have given me a good idea. I do not have a milling machine, but perhaps my bench drill would have the requisite rigidity and precision. Thank you.
  13. #10
    Bolle's Avatar
    Jan 2016
    very interesting!
