Results 1 to 6 of 6
Thread: Honda HA-420 light business jet - video
    carloski (Nov 21, 2022), nova_robotics (Nov 21, 2022)
    Supporting Member schuylergrace's Avatar
    Sep 2020
    Mesa, Arizona
    I was wondering why they mounted the engines on those weird pylons, so I asked the Googles, and the Googles spake thusly: "...a configuration called Over-The-Wing Engine Mount, or OTWEM, by Honda Aircraft. This configuration maximizes cabin space by removing the structure required to mount engines on the rear of the fuselage."
    For topical application, only. Not to be taken internally or used in com-
    bination with other drugs or alcohol, except as directed by your shaman.
    Do not operate heavy equipment, unless you actually know how to.
  4. The Following User Says Thank You to schuylergrace For This Useful Post:
    Altair (Nov 22, 2022)
    Quote Originally Posted by schuylergrace View Post
    And at the same time introducing high torsional stresses into the wings
    Sep 2020
    Mesa, Arizona
    Well, that's not much/any worse than when they sling them under the wings. They are closer to the fuselage, but the pylons are also taller. I'm sure, though, that it all went into the aerodynamic soup-pot they used to squeeze every bit of performance this thing. It sure ain't your daddy's Civic!
    They obviously had to mount the engines somewhere. Mounting them forward and under the wings on such a small air frame would have created a host of different problems, the wings would have had to be mounted higher off the ground for one, this would have meant either a much taller profile to the aircraft and greatly altering the design and weight of the fuselage just for starters, or much taller landing gear mounting adding more weight and difficulty in the ability to stow the gear away in flight.
    Shorter high mounted pods on top of the wings either forward mounting or to the rear may have been an option though at the cost of noise in the cabin for one.
    So many things involving the aeronautics of an aircraft must be considered when designing, and Honda has a reputation of figuring things out, though not always on the first go round
    Supporting Member jackhoying's Avatar
    Apr 2014
    Fort Loramie, Ohio
    jackhoying's Tools
    Here is a photo of the Honda Jet that I took at Oshkosh, 2012.
  9. The Following 2 Users Say Thank You to jackhoying For This Useful Post:
    Frank S (Nov 22, 2022), schuylergrace (Nov 22, 2022)
