Results 1 to 10 of 10
Thread: Hook razor blades in an oscillating tool - video
    Hook razor blades in an oscillating tool. By Chris Notap. 3:14 video:
    Guiding a razor with a button - GIF
    Vintage razor sharpener - GIF
  2. The Following 13 Users Say Thank You to Jon For This Useful Post:
    Andyt (Jan 18, 2020), baja (Jan 18, 2020), bgerens (Jan 17, 2020), Frank S (Jan 17, 2020), Grego009 (Jan 19, 2020), high-side (Jan 18, 2020), Inner (Jan 17, 2020), rgsparber (Jan 21, 2020), Scotsman Hosie (Jan 18, 2020), Sprig1 (Jan 18, 2020), thehomeengineer (Jan 18, 2020), Tule (Jan 19, 2020), verticalmurph (Jan 17, 2020)
    Marion, Iowa
    metric_taper's Tools
    The only time I used one of these hook blades was to cut roofing where I removed part of the ridge shingle course to install a ridge vent. It was a pain pulling by hand. This would have made that and easy task.
    For years I thought these oscillating saws were a non needed tool. But when you can plunge cut straight down in to oak hardwood flooring to install a new floor vent, and end up with a rectangular hole to the size you want, it really was a worthwhile tool. I did burn my harbor freight saw up plunge cutting a 2x4 for 32 inches, just too much time spent where I exceeded the duty cycle of the saw motor.
    The other place they are handy is under a sink cabinet, where you need to enlarge or make a hole for the plumbing drain and supply pipes, you can get in where it's too tight for any other saw.
    I wouldn't be caught without my osolating saw. I keep a good selection of blade shapes for many different tasks. They are great gasket scrapers just grind an edge on a worn out blade and have a go.
    I hadn't noticed a hook blade attachment for them but this idea would be tons cheaper than a blade made for that purpose or just grind a hook into an old blade then hone it sharp with a Dremel tool
    Thanks for sharing
    Jul 2019
    What an awesome idea. Someone had a lot of fun cutting up their carpet.
    Quote Originally Posted by Scrounga View Post
    Yeah et his wife was really proud of him
    I think you are really on to something with that idea! First time I ever saw one of these power tools was on a very old video (40 years ago?).It was a surgical procedure where they were cutting a bone protrusion (bunion) off of a patients foot. I think it was air operated. I had never seen a oscillating saw before.
    Jun 2012
    Harvey Melvin Richards's Tools
    I broke my arm in 1962 or 63 and the Dr cut off my cast with something like an oscillating tool. He said it wouldn't hurt the skin, yet I got cut from it.
  9. #8
    Commercial versions exist. This Dremel variety...
    https://www.amazon.com/Dremel-MM430-...9378413&sr=8-4
    has two edges permitting cutting on both the push and the pull stroke.
    A slightly different version of the same thing...
    https://www.amazon.com/One-Fit-Featu...378413&sr=8-19
    The DeWalt variant has a larger diameter to move the tool farther above the material being cut...
    https://www.amazon.com/DEWALT-DWA421...9378413&sr=8-6
  10. The Following User Says Thank You to mklotz For This Useful Post:
  11. #9
    Supporting Member Hans Pearson's Avatar
    Jan 2017
    Thanks for that. I have been using hook blades for years and have always had a problem of one sort or another. Looking forward to seeing if my oscilating tool will accept those blades.
  12. #10
    Supporting Member NeiljohnUK's Avatar
    Dec 2017
    NeiljohnUK's Tools
    Looks useful, I'll try them in mine, but I suspect neither of mine will clamp them being lever action clamps, I'll continue creating 'knife' blades from worn out saw type blades though.
