Page 24 of 35 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 LastLast
Results 231 to 240 of 345
Thread: The house next door...or how to NOT build a house
  1. #231
    Lake Tahoe
    IntheGroove's Tools
    My house can handle huge loads without collapsing or leaking...
  2. #232
    Quote Originally Posted by IntheGroove View Post
    Fairly low pitched roof for a snow load area such as Tahoe. 4 feet of wet fresh pack snow would be like having 6 inches of water on your roof or about 31lbs per sq. ft figure a 1200 sq foot roof you are talking about an additional 37,200 lbs on the structure of the house, and that is what some builders don't think about they build the roof to take a 100 lbf load but have only 2x4 stud walls and very little wind bracing
  3. #233
    Lake Tahoe
    IntheGroove's Tools
    That is over 6 feet of snow. The walls are solid cedar, 6.5 inches thick...
  4. #234
    That will work. Hard to beat a solid wall made out of most anything
  5. #235
    jdurand's Tools
    Here's today's pictures. Raining a bit so I won't drone on.
    In the first one you can see the house from a bit over a block away, this is quite a ways uphill. You can't see our house but this one pops up.
  6. #236
    Lake Tahoe
    IntheGroove's Tools
    I still think it's really nice that there will be a engine hoist at the entryway...
  7. #237
    jdurand's Tools
    My wife asked who's going to clean all those windows that open onto the flat roof? There's quite a few of them and they're extension ladder distance from the inside floor and there doesn't appear to be a hatch to get onto either of the roof...not to mention the extension ladder to reach said hatch.
  8. #238
    Lake Tahoe
    IntheGroove's Tools
    Those windows will never be cleaned...
  9. #239
    jdurand's Tools
    At our new house they're working on the stair forms. They were expecting to use a standard sharp wedge winder, we said no. We compromised at the newer recommended truncated wedge but that means they needed to redo the forms.
    Here's the fierce winter there
    Attachment 32458
    The snow is already melted and they're working away to keep on schedule.
  10. #240
    jdurand's Tools
    Tomorrow should be clear and sunny so I will try to get some good drone shots during the day (they don't work on Sundays). If the weather is calm I'll fly off the patio roof which gives me much more room for maneuvering and might get some close shots of their handiwork.
    Today was nice but I wound up working on an exercise machine we have. A steel plate fractured around a motor mount so I contacted the manufacturer yesterday. Since it was only 5 months old they gave a full refund and said keep it.
    So, today I wire brushed off the paint and prepared to weld a brace on to restore functionality. What, you thought I was going to salvage the motor? I though of that but don't need the motor plus we like the exercise machine and want it fixed.
    Anyway, pulled out the flux core welder and...&^%#$@! The wire feed assembly doesn't feed the wire. On inspection a plastic bit broke. On a web search they only sell the entire assembly (of course) for $90. So, I gathered tools, parts, duct tape, glue, and chewed some gum. It should hold for a while, I'll fix the machine tomorrow and then give the welder to someone as a gift. We'll buy a new one after we move Aliexpress is really handy.
