Results 1 to 4 of 4
Thread: How to add an ejection tang to a Morse taper for a metal lathe
    Supporting Member xynudu's Avatar
    Dec 2015
    xynudu's Tools
    Hi all,
    This is a relatively simple job, but newbies may be unsure of how to go about it.
    Cheers
    Rob
  2. The Following 6 Users Say Thank You to xynudu For This Useful Post:
    emu roo (Mar 15, 2021), freddo4 (Mar 15, 2021), Home-PC (Mar 15, 2021), Jon (Mar 19, 2021), nova_robotics (Mar 15, 2021), Ralphxyz (Mar 15, 2021)
    Thanks xynudu! We've added your Morse Taper Ejection Tang to our Machining category,
    as well as to your builder page: xynudu's Homemade Tools. Your receipt:
    emu roo (Dec 31, 2025)
    Dec 2016
    Ralphxyz's Tools
    Thanks, I need to do this!
  6. The Following User Says Thank You to Ralphxyz For This Useful Post:
    Jul 2014
    North Island, New Zealand.
    NortonDommi's Tools
    Most people cut the tang off if they are going to use a tanged arbor in a lathe tailstock. Closed barrel tailstocks have a stop inside that will release the arbor when it is wound in all the way. Tangs interfere with seating in these designs. Open barrel tailstocks you hit the end of the arbor with a punch.
    The ejection tang is more for use in a pedestal drill for removal from the quill.
    The easiest solution is buy the correct arbor for the job. If you have a mill with the same taper by an open end threaded arbor to suit the draw-bar of choice and some buttonhead screws in the appropriate thread, this lets you fit a screw for use in the tailstock. Most pedestal drills have hollow quills so you can use a draw-bar on these as well but a tang is easier.
  8. The Following User Says Thank You to NortonDommi For This Useful Post:
