Hi wardbob,
Jon said it 'several times', could you perhaps list the fractures/breaks/displaced disks?Just the spine though.
Levers and pulleys can acheive wonders, aside from a couple of pry bars I regulary call into use a 2-ton 'come along',(cable winch), and something that gets overlooked a x6 meat pulley. The rope can be tied off easily, does not mar finishes and the whole thing wieghs about 1 pound and can store easily. I recently removed an Onan gen set from a boat that is going solar wieght 375lbs, was an easy job and pulling a rope is quicker than a ratcheting winch, just have to be sure everything done safe as if you let go uh oh! Jib clinches as used on yachts are good if you can secure them.
We've just had a lick by the tail of a cyclone here and I found a water issue with the garage. I knocked up a Thein seperator from a couple of paint pails and dug some holes deeper than what my borrowed manual hole auger could do based on this:
Worked beut.https://holeymoleydigger.com/product...e-core-digger/
