Cheers guys, Here is another forge burner build. This is an easy burner to build on the cheap! Can also be run in your forge without electricity (which is required with a blown burner).
Yall have a good weekend! :rocker:
https://youtu.be/SAP8Xho_I6w
Thanks JKeetonKnives! We've added your Venturi Forge Burner to our Forging and Casting category,
as well as to your builder page: JKeetonKnives's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-venturi-forge-burner"> <img src="/uploads/225646/homemade-venturi-forge-burner.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-venturi-forge-burner">Venturi Forge Burner</a> <span> by <a href="https://www.homemadetools.net/builder/JKeetonKnives">JKeetonKnives</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/burner'>burner</a> </div> </div> </div> </div>
Thanks Altair!
