Results 1 to 6 of 6
Thread: How concrete staircases are trimmed - GIF
    May 2024
    nova_robotics (Jan 25, 2026)
    Lake Tahoe
    IntheGroove's Tools
    I wonder how they could be built the correct size so no trimming is necessary...
  4. The Following User Says Thank You to IntheGroove For This Useful Post:
    Quote Originally Posted by IntheGroove View Post
    What most likely happened was someone decided an elevator should be installed but the stairs were already cast to have enough room to accommodate the shaft way the stairs had to be cut back.
    albertq (Jan 25, 2026), cognitdiss (Jan 25, 2026)
    Writing a quote to my own post.
    I've personally had to have this done a few times over in Kuwait. Once I made a contractor cut an entire support wall out and relocate it half a meter so I could install a cargo lift to lower exotic cars to the basement of a 5-story house being built. He had only left 2.2meters of width. I mean get real would you attempt to drive a Bugatti mistral that is 2.161 meters wide through a 2.2-meter opening?
    Lake Tahoe
    IntheGroove's Tools
    From the looks of the saw its a common procedure...
    There are a lot of companies who do nothing else but cut concrete. In floors, walls, ceilings and yes stairways. Most that I have done business with though will usually have the guards on the blades with water spraying on them. Blades are not cheap and water helps them to last 10 times longer.
  10. The Following User Says Thank You to Frank S For This Useful Post:
    IntheGroove (Jan 25, 2026)
