The only "perfect" I know on Earth is in math. 1 +1 perfectly equals two. "Perfect", like beauty, is in the eye of the beholder. The same goes for the term "accurate."
Rick
Even in math, though, perfection can be defined, but not achieved.
A (perfect) circle is defined as the locus of points equidistant from a central point. Yet no one has ever constructed a perfect circle.
Irrational numbers are another case. There are numerous infinite series for pi but, even after millions of digits, we don't have an exact value (and never will).
One must be careful. Mathematicians are very careless in their choice of names for mathematical entities. As an example, the solution to the equation:
x² + 1 = 0
was termed an "imaginary" number. There's nothing imaginary about it and it's used widely in many real world applications of math.
They also decided to call numbers equal to their aliquot sums "perfect", e.g. 6 = 1 + 2 + 3. While it's an interesting and fairly rare property, there's nothing "perfect" about it, other than its poorly chosen name.
So many people going on and on and on about perfect. Give it a rest, bloody ridiculous!
I'm interested in the topic, not the definition of perfect. So no, but, since you're clearly more interested in the definition of perfect, why not start your own thread on perfect, rather than try to derail this one?
The internet in a nutshell; 50% cat videos and 50% pedants desperately waiting for an opportunity to correct someone. Correcting colloquialisms and hyperbole as if they were literal statements not a constructive hobby.
Some people are just incapable of giving somebody a pat on the back and saying "well done." Gotta tear them down and make them regret participating in the first place.
B- for initiative. Need to study "TIR." Your mounting "stub" is not centered. Therefore your centering efforts will all have the error of your mount. I posit that you saw a version of this in a catalog or a YouTube, and said "saw it on the Tube, I can do that."
Do it again but this time use a piece of stock four times bigger diameter. Get a combination square and layout the crossing lines to find center at the intersection. Prick the intersection, punch the intersection, drill the intersection. Now you've laid out and performed a center drill that, if you practice, should be accurate to around 3 to 5 thousandths of an inch. No need for new gizmo, you've mastered the skill. Cheers.
Me I'm lazy I usually just chuck things up in the lathe and spin them running a center drill into them. If I am extremely worried about being absolutely concentric with the OD then I'll toss on the 4 jaw and use a magnetic base dial indicator to center it up, when the needle doesn't move more than half a mark in either direction it is close enough
That works perfectly (oops I said it again) but not everyone has a lathe, also if you have a bigger part with a round feature that needs 'perfect' center drilling, this method comes in handy. If you need to center a lot of parts it is indeed nice to have a wiggler.
