Thread: How to Drill a Straight Hole in a Tin Sheet
    Supporting Member liberal's Avatar
    Nov 2018
    liberal's Tools
    Thumbs up How to Drill a Straight Hole in a Tin Sheet
  2. The Following User Says Thank You to liberal For This Useful Post:
    mwmkravchenko (Nov 3, 2021)
    Nov 2018
    I've always just used a step drill (Unibit).
  4. The Following User Says Thank You to Fast.Eddie For This Useful Post:
    KustomsbyKent (Nov 1, 2021)
    Apr 2016
    Buffalo, NY
    Second hole isn’t quite straight. Could be size of the drill makes a difference. I’ve seen this before. Nice idea.
    I'm not sure what "neat" and "straight" mean in this context but the larger 15 mm hole is distinctly trilobal, not circular.
    Use of a step drill, as suggested, is definitely preferable. Not only will you get a circular hole, but it will be much easier to place it precisely; precision locating on wood is an oxymoron.
  7. The Following User Says Thank You to mklotz For This Useful Post:
    Nov 2018
    liberal's Tools
    I just needed to use wood blocks from a denser wood.
    Perth Ontario Canada
    You can precisely locate in wood, it takes a pilot hole. Through another piece of wood. Do it rather regularly up to 6 inch diameter when I use large hole saws.
    This is a method that works, and not all required hole sizes are available on step drills. I have quite a few of those to
  10. The Following User Says Thank You to mwmkravchenko For This Useful Post:
    liberal (Nov 3, 2021)
  11. #7
    Thanks liberal! We've added your Sheetmetal Drilling Method to our Drilling and Drill Presses category,
    as well as to your builder page: liberal's Homemade Tools. Your receipt:
