Results 1 to 4 of 4
Thread: How high tensile chain is made - GIF
Hybrid View
    How high tensile chain is made.
    Chain making GIFs
    Making heavy duty chain - GIF
  2. The Following 13 Users Say Thank You to Altair For This Useful Post:
    baja (Jan 4, 2019), Beserkleyboy (Jan 3, 2019), blkadder (Jan 3, 2019), emu roo (Jul 2, 2025), neilbourjaily (Jan 3, 2019), NortonDommi (Jan 9, 2019), oldpastit (Jan 6, 2019), PJs (Jan 4, 2019), ranald (Jan 5, 2019), Seedtick (Jan 3, 2019), Tonyg (Jan 4, 2019), tuchie (Jun 19, 2025), volodar (Jan 4, 2019)
    Aug 2016
    wizard69's Tools
    Making chain has always fascinated me. I find the welding process especially intriguing.
    This machine makes for an interesting question because it looks like it can make a chain of any length. The question being how long does the chain need to be before it can’t support its own weight?
  4. The Following User Says Thank You to wizard69 For This Useful Post:
    Sep 2012
    Hinchinbrook QLD
    I'm guessing pretty long
    Quote Originally Posted by wizard69 View Post
    10 mm grade 100 lifting chain is rated at 4.0T W.L.L. and by itself weighs 1.0T per 400 m, so a single link could suspend 1.6 km of chain below it at its rated limit, which would be well below its breaking capacity.
    cheers Phil
  6. The Following User Says Thank You to 12bolts For This Useful Post:
    Jan 2018
    Black Mountain Queensland
    ranald's Tools
    Phil has made an excellent point but not sure if that answers your question fully. chain is not like flat bar ,obviously, which quickly bends due to its own weight as does pipe & even rhs.
    lifting chain is often used incorrectly for other purposes & can suffer from forces other than those for lifting. Used for towing for example can stretch the links. dragging through a fire can change the properties without noticable external damage. Nicks, like a knot, also affect it safe working load. when it comes down to the point the very old addage "a chain is only as strong as it's weakest link" is correct. I believe that w.l.l & s.w.l takr into consideration various angles from vertical to almost level & the pressures therein & on. A good rule of thumb if damage like nicks, & stretches are evident then they must not be more than 10% of the link involved or the chain is not safe to use. This is also true of chain used for other purposes (beside lifting) eg: securing a piece of plant using "dog(s)".
