Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
Thread: How the last guy tightened it - GIF
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    I can't be the only one that wants to know where I can get that breaker bar. That's stout!
  2. #12
    Oct 2016
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    have they never heard of a torque multiplier?
  3. #13
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I had a Proto breaker bar that was probably that strong. before I got my 1" torque multiplier there were numerous times when I had used a 6 ft pipe as a cheater although mine happened not to be a bent up piece of scrap pipe.
    But if you notice on the ground there appears to be at least one breaker bar that had failed to live up to the abuse
  4. #14
    Feb 2018
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have bent pipe wrenches that way.
  5. #15
    Unkle Fuzzy's Avatar
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have an old Mustang Skid Steer. The motor drive sprockets torque to 800-850 ft lbs. The service manual has a table that references Body weight and cheater bar length to achieve that torque.
    It sounds laughable but I bought it cheap because it wouldn't pull on one side. That nut on the drive motor backed off and sheared the key in the sprocket. After I made a new tapered center to weld into the sprocket, I made damn sure I got it to the specified torque.
  6. #16
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Unkle Fuzzy View Post
    I built a drawworks for an oil drilling rig that had 54" diameter disk brakes the hydraulic calipers had 5 2' bolts to hold them together the instruction sheet said heat the 20" long bolts to 400f then use a 10 foot long pipe with 2 men bouncing their weight on it We had an 1 1/2" drive hydraulic impact to pre tighten them
  7. #17
    Jul 2014
    North Island, New Zealand.
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Impact wrenches and torque multipliers are good things.
    Post your reply!
    eBooks for Supporters
