Coupon code for 20% off membership: SPRING20
Results 1 to 9 of 9
Thread: How to Make a Belt Sander Holder for Your Lathe - Tiny and Simple!
    Supporting Member AB-SHOP's Avatar
    Aug 2022
    Italy
    AB-SHOP's Tools
    Smile How to Make a Belt Sander Holder for Your Lathe - Tiny and Simple!
    Good morning everyone,
    I built a simple support for polishing the cylindrical surfaces on the lathe, it is useful to avoid getting close to the piece with gloves (not in safety) but also to remove cents for the assembly of a bearing for example.( it also depends on the grit of the sandpaper, 80,240,400 etc)
    The parts to pay attention to are the seats for the Delrin wheels (by screwing the pins the wheels get the right play to rotate and the pin is screwed up to the support of the counterbore and no more)
    The interlocking millings are also important, to finally obtain a precise coupling between the vertical and horizontal parts!
    I hope you like it,
    A big Ciao from Italy !!
    Alberto.
    Save 20% on Membership
  2. The Following 14 Users Say Thank You to AB-SHOP For This Useful Post:
    Christophe Mineau (Feb 2, 2023), EnginePaul (Feb 3, 2023), Home-PC (Feb 2, 2023), Inner (Feb 3, 2023), johncg (Feb 6, 2023), Jon (Feb 2, 2023), kboy0076 (Feb 10, 2023), metric_taper (Feb 3, 2023), schuylergrace (Feb 1, 2023), Scotty1 (Feb 2, 2023), Skun Knuckles (Feb 1, 2023), Sleykin (Feb 7, 2023), Toolmaker51 (Feb 5, 2023), trevor_60_r (Feb 6, 2023)
    Oct 2019
    Germany
    uv8452's Tools
    Dear Alberto
    grinding on a lathe is a serious crime.
    Ulrich
    Jul 2014
    France, Brittany !
    Christophe Mineau's Tools
    I like this little depth gauge
    Cheers !
    Christophe
    Facebook : La Belle Note
    Aug 2022
    Italy
    AB-SHOP's Tools
    Ciao Christophe, it is very useful when you under the tool of the milling machine!! Ciao from Italy, Alberto
  6. The Following User Says Thank You to AB-SHOP For This Useful Post:
    Aug 2022
    Italy
    AB-SHOP's Tools
    Ciao Ulrich, i understand what you mean and thanks for your message: but i think also that it exist the “ to clean” the lathe, that I do every time I use my lathe; and i will use this device when I will have to polish a surface for a bearing and I don’t make bearing shaft every day, while it only takes once to get really hurt..!
    Ciao from Italy,
    Alberto.
  8. The Following User Says Thank You to AB-SHOP For This Useful Post:
    Thanks AB-SHOP! We've added your Lathe Belt Sander to our Lathe Accessories category,
    as well as to your builder page: AB-SHOP's Homemade Tools. Your receipt:
  10. #7
    Jul 2014
    France, Brittany !
    Quote Originally Posted by AB-SHOP View Post
    yes ! If done by yourself, you could present it here (if not already done ), small simple tools are often the most successfull
    Cheers !
    Christophe
  11. #8
    Aug 2022
    Italy
    AB-SHOP's Tools
    Thanks Christophe, i will take into consideration what you wrote " simple tools", also if sometime make the simple is more difficult then the bigger !! Alberto
  12. #9
    Congratulations AB-SHOP - your Lathe Belt Sander is the Homemade Tool of the Week!
    Another big week around here, but this is a nicely-designed tool that will make lathe sanding safer in style.
    After last week's winning Guided Die Holder by AB-SHOP, that's two wins in a row. Although nobody has ever won this award three times in a row, we have a handful of other two-in-a-row winners:
    Brendon in 2015: Marking Gauge and Dovetailing Bench
    mklotz in 2016: Bench Block Enhancements and Model Cement Mixer
    tonyfoale in 2016: Horizontal Milling Machine and Drum Brake Grinder
    rossbotics in 2017: Tilting Dividing Fixture and Dial Indicator Attachment, and again for Center Punch Guide and Deburrer
    thehomeengineer in 2018: Ring Roller and Axle Stands
    Stevohdee in 2018: Milling Machine Power Feed and Tool Post Grinder
    Mark Presling in 2019: Demagnetizer and Quick Change Indicator Holder
    tonyfoale in 2021: Treadmill Motor Modifications and Cross Slide Screw Conversion
    Drop-In Anchor Plugs by earz
    Countersink and Chamfer Cutter by PaulsGarageProjects
    Mill Head Angle Setting Tool by Hill Top Machine Works
    Gear Cutting Attachment by Volodymyr Zhadlun
    Screw Feeder by fergiomaria
    Scribe by Evgeniy Budilov
    Notching Tool by troyhaack
    Belt Oil Skimmer by Alans Home Workshop
    Tap Holder by BuffaloJohn
    Lathe Indexing Wheel by fergiomaria
    Log Arch by Andrey Konovalov
    Washer Drilling Fixture by Alans Home Workshop
    Ratchet Strap Holder by ductape
    Sanding Wheel by diy creative crafts
    Grinder Tool Rest by Improvised DIY
    Chainsaw Winch by Poland Mechanic
    Die Holder by Occasional machinist
    Foam Sanding Drum by Philip Davies
    Sandblaster by Mr.DK DIY
    Compound Slide Lock by mr_modify1
    AB-SHOP - you'll be receiving a $100 online gift card, in your choice of Amazon, PayPal, or bitcoin. Please PM me your current email address and gift card choice and I'll get it sent over right away.
    This is your 4th Homemade Tool of the Week win. Here are all of your Homemade Tool of the Week winning tools. Congrats again
