Results 1 to 10 of 19
Thread: How to make discs for Dremel fast and cheap
    Supporting Member PowerMk's Avatar
    Mar 2019
    PowerMk's Tools
  2. The Following 27 Users Say Thank You to PowerMk For This Useful Post:
    69G T O (Jun 8, 2021), Andyt (Apr 4, 2019), baja (Apr 4, 2019), bugsley (Jun 15, 2021), Bummers (Apr 7, 2019), Bverysharp (Apr 5, 2019), cmarlow (Apr 3, 2019), davidschutt (Oct 21, 2025), emu roo (May 3, 2024), Floradawg (Jun 5, 2021), H.L (Jun 5, 2021), Home-PC (Jun 7, 2021), JoeVanGeaux (Jun 4, 2021), johnsmachines (Apr 3, 2019), Jon (Apr 4, 2019), Mikery2 (Jun 12, 2019), natie123 (Apr 3, 2019), oldpastit (Apr 4, 2019), Paul Jones (Apr 15, 2019), philippacificnw (Aug 3, 2025), Priemsy (Apr 7, 2019), rgsparber (Apr 7, 2019), rlm98253 (Oct 4, 2022), Scotsman Hosie (Apr 6, 2019), Seedtick (Apr 4, 2019), tuchie (Jan 20, 2024), wolfpaak (Apr 8, 2019)
    Thanks PowerMk! We've added your Dremel Discs to our Rotary Tools category,
    as well as to your builder page: PowerMk's Homemade Tools. Your receipt:
  4. The Following 4 Users Say Thank You to DIYer For This Useful Post:
    bugsley (Jun 15, 2021), emu roo (Oct 16, 2025), hansgoudzwaard (Apr 18, 2019), PowerMk (Apr 4, 2019)
    Supporting Member natie123's Avatar
    Sep 2017
    Eastern Cape, RSA
    natie123's Tools
    Thanks PowerMK. Great idea to save $ and to use those leftover discs.
  6. The Following 2 Users Say Thank You to natie123 For This Useful Post:
    emu roo (Oct 16, 2025), PowerMk (Apr 4, 2019)
    Feb 2018
    Fantastic idea! And they don't explode like the ceramic ones Dremel sells.
  8. The Following 2 Users Say Thank You to VinnieL For This Useful Post:
    Oct 2018
    What kind of bit are you using to drill the arbor holes in the center of the disk?
  10. The Following 3 Users Say Thank You to cmarlow For This Useful Post:
    emu roo (Oct 16, 2025), PowerMk (Apr 4, 2019), Priemsy (Apr 7, 2019)
  11. #6
    Mar 2019
    PowerMk's Tools
    Quote Originally Posted by natie123 View Post
    Quote Originally Posted by VinnieL View Post
    Quote Originally Posted by cmarlow View Post
    Thank you very much guys!!!!! Im so happy you like it!
    Yes natie123 and its easy. You can try it.
    VinnieL yes they dont explode and you have more cuts!
    cmarlow Im use my old drill bits because worn out. You can make about 50 disc with 1 drill bit or you can do it with a new drill bit with your hands it take more time but it does not destroy the drill bit.
  12. The Following 4 Users Say Thank You to PowerMk For This Useful Post:
    cmarlow (Apr 4, 2019), emu roo (Oct 16, 2025), hansgoudzwaard (Apr 18, 2019), Priemsy (Apr 7, 2019)
  13. #7
    Oct 2018
    Thanks again.
  14. The Following 2 Users Say Thank You to cmarlow For This Useful Post:
  15. #8
    Feb 2018
    Fillmore, Indiana (USA)
    Great idea.
    Quote Originally Posted by PowerMk View Post
    What kind of disk are you cutting up to make them? I haven't seen anything I could cut with scissors.
  16. The Following 2 Users Say Thank You to Chevymanjohn For This Useful Post:
    emu roo (Oct 16, 2025), PowerMk (Apr 5, 2019)
  17. #9
    Jan 2018
    Black Mountain Queensland
    ranald's Tools
    My Concerns=
    This is interesting providing one owns a VARIABLE speed multi tool that goes as slow as 13000 rpm (the MAX RPM FOR MOST CUTTING DISCS I'VE ENCOUNTERED) & one remembers to set the speed accordingly. I'm lucky as mine goes down to 5000 rpm. Can't & dont want to imagine a grinders cutting disc at 35000 somewhat like placing a drill bit in a quarter inch router or a die grinder. Disintegrating discs cause havoc.
  18. The Following 2 Users Say Thank You to ranald For This Useful Post:
  19. #10
    Mar 2019
    PowerMk's Tools
    Quote Originally Posted by Chevymanjohn View Post
    Thanks Chevymanjohn. Its looks easy because the speed of video its x2....
    I used 125 mm with 1.2mm thick disc for metal cutting. So you can try with 1.2mm disc .
    Quote Originally Posted by ranald View Post
    My Concerns=
    Hello ranald. The max rotation speed of disc I used is 12.250 but its not the same for disc I made for dremel because of diameter. For 125 disc max rotation is about 13.000 rmp , for 180 disc is 8.500 rmp and for 230 is 7.000 rmp. So if diameter of disc is bigger the RMP its lower. In my case diameter is 36mm. For the commercial metal cutting discs for dremel max speed is 35.000 rmp. I think the safety rmp for homemade discs is 10.000-20.000 or more based in theory.
  20. The Following 2 Users Say Thank You to PowerMk For This Useful Post:
    emu roo (Oct 16, 2025), Priemsy (Apr 7, 2019)
