In this video i made a simple tool that helps us to make external keyway without a milling machine by using only our lathe. You can watch the video of the construction and the use of it here: https://youtu.be/lZCUXazFvpo
Thanks mariost! We've added your Keyway Slotting Setup to our Machining category,
as well as to your builder page: mariost's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-keyway-slotting-setup"> <img src="/uploads/251536/homemade-keyway-slotting-setup.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-keyway-slotting-setup">Keyway Slotting Setup</a> <span> by <a href="https://www.homemadetools.net/builder/mariost_2">mariost</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/lathe'>lathe</a>, <a href='https://www.homemadetools.net/tag/keyway'>keyway</a>, <a href='https://www.homemadetools.net/tag/tool-post'>tool post</a> </div> </div> </div> </div>
