Results 1 to 5 of 5
Thread: How sawdust is manufactured - GIFs
    Found these in a set. No idea what is being made here. Toothpicks?
  2. The Following 6 Users Say Thank You to Jon For This Useful Post:
    baja (Dec 8, 2020), bigtrev8xl (Dec 8, 2020), emu roo (May 21, 2025), KustomsbyKent (Dec 7, 2020), rlm98253 (Dec 7, 2020), WorkerB (Dec 12, 2020)
    My guess is they're making parts for furniture. Tapered spindle legs with cross-drilled holes for braces/stool foot rests, etc. Can't explain the octagonal (?) bit and the ring but I can envision furniture designs that might make use of same.
  4. The Following 5 Users Say Thank You to mklotz For This Useful Post:
    emu roo (Mar 19, 2026), Jon (Dec 7, 2020), KustomsbyKent (Dec 7, 2020), Moby Duck (Dec 13, 2020), rlm98253 (Dec 7, 2020)
    Supporting Member thevillageinn's Avatar
    Jul 2017
    thevillageinn's Tools
    I agree with Marv - looked like furniture parts to me. That was an impressive pile of chips in the background of one video. Time to turn that into particle board for the next factory to turn into furniture.
  6. The Following User Says Thank You to thevillageinn For This Useful Post:
    Another set of these. Paintbrush handles?
  8. The Following User Says Thank You to Jon For This Useful Post:
    May 2018
    Boring, OR
    CharlesWaugh's Tools
    It's curious that on the wide paint brush handle routing machine they are doing a conventional cut (cutter running against the rotation fo the tool).
    You can even see the handle splinter on the outfeed end of one of the cuts.
    The two-sided copy-shaper shown in the last video is climb-cutting both sides (one spindle is running in left hand rotation).
    Having been a woodworking engineer for 20 years, I notice these things...
    Charles Waugh
    www.charleswaugh.com
  10. The Following User Says Thank You to CharlesWaugh For This Useful Post:
