https://youtu.be/61xWmVUgpGo
Thanks RCTURKA! We've added your Drill Bit Shaping and Sharpening Method to our Sharpening category,
as well as to your builder page: RCTURKA's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-drill-bit-shaping-and-sharpening-method"> <img src="/uploads/253130/homemade-drill-bit-shaping-and-sharpening-method.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-drill-bit-shaping-and-sharpening-method">Drill Bit Shaping and Sharpening Method</a> <span> by <a href="https://www.homemadetools.net/builder/RCTURKA">RCTURKA</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/drill-bit'>drill bit</a>, <a href='https://www.homemadetools.net/tag/sharpening'>sharpening</a> </div> </div> </div> </div>
How do you know you are exactly at center, just by eye?
Ralph
Yes, just by eye. Believe me, it's not hard!
Not hard but not exact, I am just trying to sharpen drill bits and notice that I can easily grind too much off a side and not notice until I try the drill on metal and then it extremely wanders. For drilling wood I can see where it might not matter.
Ralph
Interesting approach. I especially like the long point which should make hitting the target cross much easier. With conventional spur bits I often have to get my eyes down to bit level just to see where the sharp point will start, this design eliminates that issue.
The Kreg Pocket Hole wood bit has a pointed center. I wondered how to sharpened them. Now I ha a good idea of what to do. I was always concerned
about centering the point.
Ralph
good job,,but u did use a bench grinder with a jacket on??!! and u did drill holes by holding a piece of wood,,,and u did go over 10 minutes, sooooooo,,, u get this weeks Sam Kinison award,,,,OOH,OOH,OOOOOOOOOOOH,OOOOOOOH,OOH,OOH,OOOOOOOOOOOOH!!!!!
