-7.5kW/380V
-200 bar
-hydraulic cylinder fi 110mm/50mm x 400mm
-hydraulic oil min.30l, max.80l
-briquette fi 75mm
-safety control voltage - 24V DC
-7.5kW/380V
-200 bar
-briquette fi 75mm
Thanks darkoford! We've added your Briquette Press to our Miscellaneous category,
as well as to your builder page: darkoford's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="http://www.homemadetools.net/homemade-briquette-press-7"> <img src="/uploads/217525/homemade-briquette-press-7.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="http://www.homemadetools.net/homemade-briquette-press-7">Briquette Press</a> <span> by <a href="http://www.homemadetools.net/builder/darkoford">darkoford</a></span> </div> <div class="tags">tags: <a href='http://www.homemadetools.net/tag/press'>press</a>, <a href='http://www.homemadetools.net/tag/charcoal'>charcoal</a> </div> </div> </div> </div>
Nice machine. If you do a lot of cooking, that little press will pay for itself quickly at the current price of those wood pucks. Do use anything for a binder, or is it just wood only?
Price of briquette in Croatia is $2-10kg . I can make 200-300kg / h depending on the type of wood.
Only dry wood without binder.
What creates the resistance to compress the sawdust rather than just push it out loose?
The tube has a cone (1-2 °) inside and it provides great resistance to the passage of sawdust.
