I Built a HOMEMADE Flexible Claw Pick Up - 100% DIY
For the construction I used a 6 mm diameter PVC pipe, steel spring, spring piston, steel wire. Watch the video and tell me what you think?
https://youtu.be/Ir5jAcT7cxw
Thanks diyfixman! We've added your Flexible Claw to our Miscellaneous category,
as well as to your builder page: diyfixman's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-flexible-claw"> <img src="/uploads/236131/homemade-flexible-claw.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-flexible-claw">Flexible Claw</a> <span> by <a href="https://www.homemadetools.net/builder/diyfixman">diyfixman</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/holding'>holding</a> </div> </div> </div> </div>
thank you :thumbsup:
