Results 1 to 10 of 11
Thread: Impact screwdriver - GIF
    Altair's Avatar
    MsLizVt (Apr 21, 2021), rlm98253 (Apr 17, 2021)
    Lake Tahoe
    IntheGroove's Tools
    I remember the days when you couldn't disassemble a motorcycle engine without one of those...
  4. The Following User Says Thank You to IntheGroove For This Useful Post:
    rdarrylb (Apr 18, 2021)
    Oct 2016
    old kodger's Tools
    The trick to undoing screws like that without an impact screwdriver, is to use a drift and whack it on the end before even lifting up a screwdriver. This marginally drives the screw forward releasing the tension. Did it with some brake drums only yesterday, (mind you that tells you that my workshop is a mess and I can't find the impact driver).
  6. The Following 2 Users Say Thank You to old kodger For This Useful Post:
    jimfols (Apr 18, 2021), MsLizVt (Apr 21, 2021)
    Jul 2019
    Ohio, USA
    This is a must for removing brake rotor screws! Now that I have a 20V impact, I don't use it as much, but still comes in handy.
    Mar 2021
    SE PA, USA
    Quote Originally Posted by IntheGroove View Post
    Especially those wonderful Phillips head screws Honda used for all their engine covers!!!
    Lake Tahoe
    IntheGroove's Tools
    And then you would buy the allen head kit that never had all the correct bolts so your left to reuse one or two of those Phillips screws with their half stripped head...
  10. The Following User Says Thank You to IntheGroove For This Useful Post:
  11. #7
    Sep 2015
    Ontario Calif USA
    This is very important. Without or before an impact driver.
    Jim
  12. #8
    Oct 2016
    old kodger's Tools
    If the impact driver is of the type that you have to whack with a hammer (as mine is) then both effects are combined into it's use.
  13. #9
    Sep 2015
    Ontario Calif USA
    The solid drift gives a more direct forward force to the fastener.
    Jim
  14. #10
    HobieDave's Avatar
    Jul 2018
    That is my secret weapon to prevent tampering by operators. Nowadays every one is a mechanic and they always quote somebody from youtube.
    You just need to tighten the screws with the impact but without using a hammer, very easy to loosen again with the impact but difficult with a normal screwdriver. Just let your coworkers know as well.
