Results 1 to 10 of 12
Thread: Improvements to the quill lock on a milling machine.
    This is probably the simplest post that I have made here, but the ratio of utility to effort is very high.
    The video says it all.
    Other tool videos at https://www.youtube.com/playlist?lis...O1hdmUIYO28Def
  2. The Following 21 Users Say Thank You to tonyfoale For This Useful Post:
    12L14 (Jul 31, 2019), albertq (Jan 4, 2024), Andyt (May 10, 2019), asterix (Nov 1, 2022), Bummers (Apr 25, 2023), Corm (Mar 28, 2019), emu roo (Jul 11, 2024), HUMARIA (Mar 28, 2019), Inflight (Mar 27, 2019), jimfols (Mar 27, 2019), johncg (Jun 25, 2021), JTC (May 11, 2019), melbakid (Jun 24, 2021), mwmkravchenko (Mar 28, 2019), RetiredFAE (Jun 24, 2021), rlm98253 (Apr 25, 2023), schuylergrace (Apr 11, 2023), Scotsman Hosie (May 9, 2019), Seedtick (Mar 27, 2019), Tonyg (Mar 28, 2019), warsztatOdZera (Mar 28, 2019)
    Sep 2015
    Ontario Calif USA
    Thanks Tony,
    Manys the time I have looked at or touched that quill lock to make sure it was not snugging up. I never dreamed of such an easy fix.
    Jim
    Of all the features making knee mills what they are; their quill lock might be the worst. It's conveniently placed but infrequently used. All kinds of aftermarket solutions have popped up; springs, magnets, counter-weights, none stayed on market long.
    It's good its found a way into the forum.
    Reversing the assembly is less common now, but an old practice.
    Probably due turnover of less committed machinists, with fewer experienced mentors.
    Jun 2018
    Louisiana
    Very clever Tony
    Mar 2014
    Beaumont, TX
    Paul Alciatore's Tools
    Neat! And it didn't cost a dime.
    Paul A.
    I didn't know that commercial solutions existed.
    Reversing the assembly ......., an old practice.
    I didn't know that either. I often reinvent the wheel.
  8. The Following 3 Users Say Thank You to tonyfoale For This Useful Post:
    Canyonman44 (Oct 5, 2023), Scotsman Hosie (May 9, 2019), Toolmaker51 (Mar 28, 2019)
  9. #7
    Thanks tonyfoale! We've added your Quill Lock Modification to our Machining category,
  10. #8
    When I posted those goofy remedies, even googling them, pulled up zero. One was called "Quill Cock"; a molded plastic counterweight in red - profile of a rooster. To not appear in X hundred-thousand returns about insignificant as can be.
    They'd been better off, compelled to front mounting; use a left hand thread for CCW operation and some kind of adjustment so it would lock without interference from casting.
  11. #9
    Both good points. A LH thread would have cost the factory nothing. An adjustment system might have added a penny or two, but at least they could have provided say 4 to 6 positions for the handle.
    In any case I have found no disadvantage with having a rear mount, I have used the rear mount for over 10 years.
  12. The Following User Says Thank You to tonyfoale For This Useful Post:
    Scotsman Hosie (May 10, 2019)
  13. #10
    Apr 2016
    this is a good idea for some, buit for me outa sight outa mind....I would still leave it tight. I just added a nice stiff spring inbetween so they were held apart. witch pretty much keep the arm up when you unlock it. and down is locked. I did that years ago....but i still check every time I use the machine.old habbets seem to be hard to break. my quill has some good marks on it from somebody not paying attn.... before I got the refurbusshed machine... I dont know who/what company refer bushed it, but i think they just had a joint in 1 hand and a spray can in the other hand....smoking their referbush and spray painting the mill. you cant fix stupid, ugly can be fixed, stupid ..not!!! good thing I didnt pay a lot for it...( it's fine, but not reworked like it should of been,or that I was led to be leave)
