Results 1 to 4 of 4
Thread: Improving the oil transfer to oiling push buttons using an O-Ring
    May 2014
    Del Mar, California
    Paul Jones's Tools
    I am sure this trick has been posted before but I found this simple modification to my machine tool oilers to work very well. Adding a Buna N No. 6 O-ring around the slight groove on the nose of the pump oiler provides a better seal to the spring loaded ball oiling points on the machine tools.
    Below is an example of oiling the ways to one of my metal lathes.
    Improving the oil transfer to oiling push buttons using an O-Ring-o-ring-improves-oil-transfer-oiling-push-buttons.jpg
    I also use a colored cable tie to identify the pump oiler based on the color of the cap to the oil container.
    Improving the oil transfer to oiling push buttons using an O-Ring-buna-n-no.-6-o-ring-improves-oil-transfer-oiling-push-buttons.jpg Improving the oil transfer to oiling push buttons using an O-Ring-color-code-oiler-based-cap-color.jpg
    Thank you for looking,
    Paul Jones
  2. The Following 4 Users Say Thank You to Paul Jones For This Useful Post:
    old_toolmaker (Mar 15, 2018), PJs (Mar 5, 2018), Seedtick (Mar 4, 2018), Toolmaker51 (Apr 8, 2018)
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    Really simple good idea Paul. Like the blue and black wire ties also. Simple, effective and out of the way.
    Thanks for posting these ideas.
    PJ
    Mark Twain
  4. The Following User Says Thank You to PJs For This Useful Post:
    Paul Jones (Mar 7, 2018)
    Thanks Paul Jones! We've added your Machine Oiler Modification to our Miscellaneous category,
    as well as to your builder page: Paul Jones's Homemade Tools. Your receipt:
    Paul Jones (Mar 8, 2018)
    Thanks Paul Jones! We've added your Lube Type Identifier to our Miscellaneous category,
