Thread: Improvised chain oil filter wrench - GIF
Hybrid View
    Improvised chain oil filter wrench. Of course, having this much access to an oil filter is a dream.
    JM3 oil filter wrench Kickstarter
  2. The Following 13 Users Say Thank You to Jon For This Useful Post:
    Andyt (Mar 31, 2020), baja (Mar 31, 2020), davesrepair (Jan 16, 2025), hansgoudzwaard (Mar 31, 2020), HobieDave (Mar 31, 2020), jimfols (Mar 30, 2020), mwmkravchenko (Mar 30, 2020), Rikk (Mar 31, 2020), sak778 (Dec 4, 2021), Scotty1 (Mar 30, 2020), Seedtick (Mar 30, 2020), Tooler2 (Mar 31, 2020), verticalmurph (Mar 31, 2020)
    Supporting Member gatz's Avatar
    gatz's Tools
    that is really clever.....and it works so well !
    even if the access is parallel to the filter body, you could still make a box-end wrench work; just need another wrench as a "cheater" to turn it.
    thanks for posting
    Oct 2016
    old kodger's Tools
    Yup, great idea, will use it where possible.
    Many years ago, I had a filter remover made by Snap-on it comprised a backing plate with a hex welded to one side and a spiral spring (clockwise) projecting from the other. when you wound it "on" the spring opened up to accommodate nearly any sized filter, as soon as you applied anti-clockwise rotation it locked on allowing you to unscrew the filter.
    There are two troubles with it (1) Snap-on don't make them anymore, and (2) it was so good that someone stole it.
