HomemadeTools.net Members
Thread: Improvised chain oil filter wrench - GIF
    Mentioned
    0 Post(s)
    Tagged
    5 Thread(s)
    Improvised chain oil filter wrench. Of course, having this much access to an oil filter is a dream.
    JM3 oil filter wrench Kickstarter
    Advertisements
  2. The Following 11 Users Say Thank You to Jon For This Useful Post:
    Andyt (03-31-2020), baja (03-31-2020), hansgoudzwaard (03-31-2020), HobieDave (03-31-2020), jimfols (03-30-2020), mwmkravchenko (03-30-2020), Rikk (03-31-2020), Scotty1 (03-30-2020), Seedtick (03-30-2020), Tooler2 (03-31-2020), verticalmurph (03-31-2020)
    Supporting Member gatz's Avatar
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    gatz's Tools
    Advertisements
    that is really clever.....and it works so well !
    even if the access is parallel to the filter body, you could still make a box-end wrench work; just need another wrench as a "cheater" to turn it.
    thanks for posting
    Advertisements
    Oct 2016
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yup, great idea, will use it where possible.
    Many years ago, I had a filter remover made by Snap-on it comprised a backing plate with a hex welded to one side and a spiral spring (clockwise) projecting from the other. when you wound it "on" the spring opened up to accommodate nearly any sized filter, as soon as you applied anti-clockwise rotation it locked on allowing you to unscrew the filter.
    There are two troubles with it (1) Snap-on don't make them anymore, and (2) it was so good that someone stole it.
    Post your reply!
    eBooks for Supporters
