Results 1 to 9 of 9
Thread: Installing a hex rivet nut - GIF
  2. The Following 5 Users Say Thank You to Altair For This Useful Post:
    desbromilow (Oct 17, 2023), kboy0076 (Oct 22, 2023), KustomsbyKent (Oct 19, 2023), nova_robotics (Oct 17, 2023), Ralphxyz (Oct 21, 2023)
    Sep 2018
    nova_robotics's Tools
    What's that first tool that cuts the hex out of the material?
    May 2018
    Boring, OR
    CharlesWaugh's Tools
    Pretty cool!
    Insert jaws
    Spread jaws open
    PULL jaws back (like a single-tooth broach) and t cuts the hex
    Insert rivnut
    Insert screw-puller into rivnut
    Tightenrivut into place
    DONE!
    Charles Waugh
    www.charleswaugh.com
    That is a far superior rivnut over the cylindrical ones
    Sep 2018
    Okay I did some digging. Looks like a couple companies offer hex rivnuts. Rivnut USA and Sherex, maybe other manufacturers but those are the only two I found. The tool to create the hex hole is not provided by either of those companies. The hex hole tool appears to be made by a company called Avdel? Maybe? I can't find any details, but here's a video of what I believe is the same tool in operation.
  7. The Following 6 Users Say Thank You to nova_robotics For This Useful Post:
    Altair (Oct 19, 2023), astroscuba (Oct 18, 2023), Inflight (Oct 21, 2023), Inner (Oct 21, 2023), KustomsbyKent (Oct 19, 2023), Ralphxyz (Oct 21, 2023)
    Sep 2020
    I too did a quick look after that video and was able to locate the hex blind nuts but never saw the cutting tool! Probably very pricy! But I can see how the hex wold prevent the blind rivit from turning in the hole. Beneficial but at a big price point.
  9. #7
    Dec 2014
    South Dakota
    KustomsbyKent's Tools
    We have used the hex nut inserts in a production setting. Since all of our parts were punched on a CNC punch, we could easily implement the hex hole.
    I've never seen that hex punching tool, that would be handy for these types of inserts.
    We also found some specialized round nut inserts that had grippers on the head/top of body and those allowed us to use a regular round hold, but those grippers provided superior resistance to torque turning.
    I believe this is the one we were using: https://fasteners.sherex.com/category/optisert-series
  10. #8
    Jan 2015
    Here you go: For $2529 from Crest Fasteners https://www.crestfasteners.com/detai...F-74290-03000#
  11. The Following 3 Users Say Thank You to Inner For This Useful Post:
    Gadgeteer (Oct 21, 2023), nova_robotics (Oct 21, 2023), Philip Davies (Oct 22, 2023)
  12. #9
    Dec 2015
    Reading, Berks, UK
    Philip Davies's Tools
    Quote Originally Posted by Inner View Post
    I’m not buying it! I’ll use a punch! I wonder whether I could us a case hardened imperial nut?
